Home > General > brembo brakes
JUCOTT01
I have left the rears alone,just modified the fronts even on the supercharged 5.0 I think the rear discs are only 5mm larger on the diameter than mine,
Fronts however were 365mm using a sliding 2 pot caliper.
Now 380mm disc with a 6 pot brembo no other changes required
Very Happy RRS MY11 BALI BLUE OVERFINCH
Post #325393 Sat Dec 17 2011 9:47am
Supacat
How much did it cost?
Post #325408 Sat Dec 17 2011 11:22am
JUCOTT01
Calipers were a bargain from flea bay £250 for the pair
Refurb and painting £150
Discs £160
Pads £160
Just a straight swapover
Overfinch decals free gratis as I just spent a small fortune with them !!!!
Post #325411 Sat Dec 17 2011 11:32am
Supacat
Thanks...off to trawl ebay Thumbs Up
Post #325427 Sat Dec 17 2011 3:10pm
JUCOTT01
[/quote] Thanks...off to trawl ebay [quote]
Supacat what MY is your sport ??
The reason i ask is it took me quite a while to decide exactly what i needed.
Pre MY10 models front hubs have a caliper bolt hole spacing of 138mm where as post MY10 is increased to 150mm
Just be careful what you buy
If you need any info just PM RRS MY11 BALI BLUE OVERFINCH
Post #325429 Sat Dec 17 2011 3:44pm
Supacat
Thanks for the additional info - MY10 TDV8 swapped out from MY57 TDV8, hence missing my Brembo callipers, although they weren't painted, so not as nice as yours.
Found this kit:
http://www.fr-rtuning-shop.co.uk/index.php...ct_id=2905
which looks very nice but is over £3k. Slightly confusing as this picture appears to show separate bells but other photos show one piece discs?
Brembo Front GT Brake System 380mm for Land Rover Range Rover Sport 2005-
6 Pistons Caliper in Blue, Red or Silver
380x34mm 2-Piece Disc Size
Discs options Drilled (1J1.9005A) or Slotted (1J2.9005A)
Post #325477 Sun Dec 18 2011 11:55am
Roberto Arenas
Spain 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
Hi , I just bought Brembo six pistons calipers sport a range 5.0 superchargued 2010. I have a Range sport 245hp TDV6 3.0 in 2010. I would like to know I need to install these calipers to my RRS .
news discs , new pads ... more???
Thank you very much.
Post #481719 Sat Dec 05 2015 7:46pm
Roberto Arenas
Photos new calipers RRS 2010 5.0 superchargued.
Post #481720 Sat Dec 05 2015 7:48pm
AS90
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HST Santorini Black
I am just doing the same you also need the dust shields as the 380mm discs are to big for the one you have on the rest is straight fit.
Post #482906 Sun Dec 20 2015 8:55am
RRSNUT
2006 Range Rover Sport TDV6 HSE Java Black
Just reading through this old post as I have bought some brembo's to refurb and was wondering where would I get the bigger dust shields from? North Wales Land Rover Club Member
RRS 2.7 TDV6 HSE. MY06. JAVA BLACK. FULL BLACK NAPPA
- CLEAR SIDE REPEATERS - SIDE STEPS - PARROT BLUE TOOTH PHONE - GENERAL GRABBER AT's - EGR VALVES REMOVED
Post #507957 Mon Oct 17 2016 2:31am
Disco_Mikey
Genuine part only, or from a breakers Thumbs Up
Post #507961 Mon Oct 17 2016 8:23am
tonywolf
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Hi I have a spare set, off my MY2013 in excellent condition that I'll be happy to sell, unfortunately Im out the country and not back till mid January if you are willing to wait? Best Regards
Tony
MY2014 SDV6 AB Dynamic
Post #507963 Mon Oct 17 2016 10:18am
Olly-ibiza
Iv just bought some 6pots off a 2015 with 380mm discs, will these bolt on to a 2008 or will I have to do some hub modification? spiteful Range Rover Sport tdv8
Post #518599 Wed Feb 22 2017 3:05pm
