Home > General > Headlights
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Headlights
Is it possible to turn off the feature where the headlights stay on after leaving the car.
Tried looking on the settings menu but it only seems to let me set the duration to a minimum of 30 seconds.
Even using the lights in manual mode the lights still stay on.
Thanks for any help
Nik. 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #322287 Wed Nov 23 2011 12:58pm
I use the fob function to turn them off manually if they're not needed
Not looked into disabling them I assumed it was in that settings menu RRS gone
Post #322293 Wed Nov 23 2011 1:24pm
Big ken
Scotland 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Turn the ignition off and the lights come on, turn it on then off again and the lights will go off.
Post #322298 Wed Nov 23 2011 1:56pm
peanutbob
2008 Range Rover Sport TDV8 HSE Zermatt Silver
But you can disable them in the settings menu using the button on the left stalk!
Post #322337 Wed Nov 23 2011 5:22pm
Nik
I don't know if this is the correct way but it worked.
Ignition off, lights turned to off.
Turn ignition one click and turn lights to on.
Turn off lights then turn ignition back.
I then tested by restarting the engine turned the lights on then off, shut engine off and bingo no welcome home lights.
Big ken i think this is what you suggested in a not so long winded way Thumbs Up
Nik 2015 Golf R DSG
Post #322338 Wed Nov 23 2011 5:31pm
Nik
Looks like I was wrong. Just been to the gym and the welcome home lights or whatever they are called were back in operation.
How do I permanently turn the this feature off????
Nik 2015 Golf R DSG
Post #322347 Wed Nov 23 2011 7:54pm
mse
Im sure its a menu function and select off, i swear ive seen it....but then i like the feature Mike
2014 Facelift Discovery
Post #322367 Wed Nov 23 2011 10:07pm
Bobby
Headlamp Timer is a driver convenience feature which illuminates the driveway after leaving the vehicle.
To select this feature, the lighting control switch must be in the headlamp or side lamp position when the ignition switch is moved from the ignition position II to the off position. The lighting control switch must be moved to the off position or AUTO position (if fitted) to activate the timer.
The timer function will then be initiated and low beam headlamps will be illuminated for the selected timer period.
In other words, maybe you are not switching off your headlights/sidelights before switching off the ignition. And if you leave your lights switch to AUTO, this function is permanent. Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #322373 Wed Nov 23 2011 11:38pm
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
In the 2010 or newer models, yes you can disable it in the menu. On the older ones you can't
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #322378 Thu Nov 24 2011 3:37am
As Bobby said, you have to turn your lights off BEFORE turning the engine off..otherwise it will enable the "follow me home" lights when the key is finally removed.
As I said before, I just blip the key fob once when I'm out the car and they go out immediately RRS gone
Post #322396 Thu Nov 24 2011 9:19am
