![]() | Home > General > Headlights |
I use the fob function to turn them off manually if they're not needed
Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282 ![]() ![]() ![]() |
Turn the ignition off and the lights come on, turn it on then off again and the lights will go off. |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
But you can disable them in the settings menu using the button on the left stalk! |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
I don't know if this is the correct way but it worked.
Looks like I was wrong. Just been to the gym and the welcome home lights or whatever they are called were back in operation.
Im sure its a menu function and select off, i swear ive seen it....but then i like the feature Mike
Headlamp Timer is a driver convenience feature which illuminates the driveway after leaving the vehicle.
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
In the 2010 or newer models, yes you can disable it in the menu. On the older ones you can't Cheers, Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers 2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT |
As Bobby said, you have to turn your lights off BEFORE turning the engine off..otherwise it will enable the "follow me home" lights when the key is finally removed.
