Home > General > Headlights |
I use the fob function to turn them off manually if they're not needed
Wed Nov 23 2011 1:24pm |
Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282 |
Turn the ignition off and the lights come on, turn it on then off again and the lights will go off. |
Wed Nov 23 2011 1:56pm |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
But you can disable them in the settings menu using the button on the left stalk! |
Wed Nov 23 2011 5:22pm |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 |
I don't know if this is the correct way but it worked.
Wed Nov 23 2011 5:31pm |
Looks like I was wrong. Just been to the gym and the welcome home lights or whatever they are called were back in operation.
Wed Nov 23 2011 7:54pm |
Im sure its a menu function and select off, i swear ive seen it....but then i like the feature Mike
Wed Nov 23 2011 10:07pm |
Headlamp Timer is a driver convenience feature which illuminates the driveway after leaving the vehicle.
Wed Nov 23 2011 11:38pm |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 |
In the 2010 or newer models, yes you can disable it in the menu. On the older ones you can't Cheers, Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers 2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT |
Thu Nov 24 2011 3:37am |
As Bobby said, you have to turn your lights off BEFORE turning the engine off..otherwise it will enable the "follow me home" lights when the key is finally removed.
Thu Nov 24 2011 9:19am |
