![]() | Home > Maintenance & Modifications > RRS TDV8 57 plate Coolant level Require Top up Every 10 days |
kennyt0804 Member Since: 18 Oct 2011 Location: Prudhoe Posts: 12 ![]() ![]() ![]() |
I am having to top up coolant level on RRS TDV8 every 10 days about 500ml each time. Any ideas??
Egr cooler leaking |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
There was a replacement expansion tank for '57' plate RRS as there was a fault with some. Mine was replaced a couple of years ago as mine kept doing that. Sons of dogs come hither and get flesh
Bearrubb1 Member Since: 02 Jan 2014 Location: Kettering Posts: 3 ![]() ![]() ![]() |
Kenny any news on the leak?? My 08 tdv8 is doing the same?? |
Carlos3 Member Since: 14 Apr 2013 Location: Chester Posts: 40 ![]() ![]() ![]() |
Had a similar problem with my TDV8 last year
Took mine in today Carlos hope they find it as pressurised mine twice and no leak told them to check where you said, fingers crossed |
Hope you get it sorted. |
I had a very slow loss of coolant on my 57 plate TDV8. Turned out to be a leak in the manifold that connects all of the coolant pipes in the V below the EGRs. 2012 SDV6 - it's missing a couple of cylinders
Was it replacement manifold?? Where did you get it fixed |
