Home > Technical > Battery Warning Lamp? |
toeuk1 Member Since: 18 Sep 2011 Location: UK Posts: 29 |
Further to the above post, battery lamp is still on. Tested battery voltage today, the voltage virtually remained constant at 13.5 Volts with engine running, despite the main beam, heated seats and radio all on!
Mon Sep 19 2011 6:20pm |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 |
Sounds like faulty diodes on the alternator, this could spell the beginning of the end for the alternator. |
Mon Sep 19 2011 6:23pm |
Sizzle TDV8 Member Since: 22 Mar 2010 Location: London Posts: 117 |
This happened to me earlier this year, exactly as you have said, then on the way to LR I got a bacon like smell and the voltage dropped . Luckily I made it to the dealership. Diagnosis was alternator foo@ed.
Tue Sep 20 2011 8:18pm |
Thanks for that gents, how long was the light on for Sizzle before it gave up? I'm booked in a LR specialist on Monday to get a new throttle pedal (engine system fault - brake & throttle pedal incompatable positions).
Wed Sep 21 2011 9:12am |
smoftah Member Since: 10 Jun 2011 Location: Kent Posts: 30 |
Just had the same come on in my car. Battery light has been on for 2 days now, does it go suddenly? |
Tue Oct 04 2011 5:08pm |
Hi Smoftah, mine kept charging for maybe a couple of hundred miles tops. Then I noticed the CD volume wouldn't increase and I was getting a message - something like "low power mode".
Wed Oct 05 2011 11:25am |
Linko Member Since: 10 Sep 2010 Location: Shropshire Posts: 61 |
I had my alternator changed last year at the main dealer I was recovered in to . The Land Rover SRO time is 2.20hrs on a Range Rover Sport TdV8. There is also an SRO to test the Alternator which is 0.20hrs. So should be nowhere near 6 hours! Cheers, Mark |
Wed Oct 05 2011 3:55pm |
Thanks for that Tony Best it get done sooner rather than later. Was the total bill scary? |
Thu Oct 06 2011 8:26am |
£711 Total. One problem just seems to lead to another though. The alternator is now ok, but because they removed the negative lead off the battery, the aftermarket in dash TV has now stopped working!
Thu Oct 06 2011 11:07am |
jules660 Member Since: 25 Apr 2012 Location: devon Posts: 16 |
Wed Apr 25 2012 6:22pm |
Just to let you know, when my alternator was replaced, the "Landrover specialist" I took the car to, charged £711 to supply and fit a replacement (warranty partially covered that). The reason for this extortionate amount was that the front of the car needed removing to complete the job - bumper, radiator etc. I've since found a much more knowledgeable local landrover specialist who assures me the alternator can be accessed from inside the engine bay by removing a few pipes/boxes. He would have charged only £100 labour + the alternator! |
Wed Apr 25 2012 11:40pm |
Thanks, Mines in an approved warranty centre that have never changed one before so i am dreading the faults and aftermath mess they may cause |
Thu Apr 26 2012 7:55am |
cuyunaNZ Member Since: 14 Jun 2012 Location: mainland Posts: 7 |
I've just pulled off the alternator on a 2008 td v8 3.6 today. If someone rekons they can pull the alt via the engine bay they are dreaming. took me ~ 3.5 hrs on the flat, a hoist would've been 2.5 |
Thu Jun 14 2012 5:16am |
Dunno how they get them out Martin all sorts of different ways people say |
Thu Jun 14 2012 5:20am |
