Home > Maintenance & Modifications > Spare wheel pressure check
oldcro
Scotland
Is there an easier way of checking the pressure in the spare wheel, other than winding the wheel down to the ground? I had hoped there was access from the tool tray but have failed to find anything.
I hope there is a blindingly obvious method I've missed as lowering the wheel is hardly fun in a garage forecourt.
Post #307895 Sun Jul 31 2011 12:09pm
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
I never even thought of this... Surely if you have a good relationship with your dealer they would do it for you gratis ??? Or maybe try kwik fit Smile
Post #307916 Sun Jul 31 2011 6:30pm
drdelrrs
Come on - it only takes about 5 mins to lower and get the wheel out at home. Stick it in the back and check the pressures at the filling station or use a foot pump!!
When you get home put it back in place.
Actually you can usually get at the valve with it lowered without taking the wheel off the winch - at least remember to put it back so the valve is at the rearmost position for future ease of checking.
Needs to be pumped up to maximum for the tyre ~ usually 40psi.
If you ever need to use it let the air out untill its correct for the front or rear.
Post #307931 Sun Jul 31 2011 7:22pm
oldcro
Scotland
Good idea... except that both are nearly 200 miles and 36 hours away. Big Cry
Post #307935 Sun Jul 31 2011 7:25pm
oldcro
Scotland
So no easier way then. Your reply seems to assume a youngish rather fit owner, none of which matches my profile sadly
Post #307947 Sun Jul 31 2011 8:05pm
drdelrrs
Hi OLDCRO. I did not assume nowt. I did my own and I'm 65; so with you in the seniors of he Forum.
Post #308118 Mon Aug 01 2011 7:29pm
barry15555
England 2006 Range Rover Sport Supercharged Bonatti Grey
DRDILL wrote:
Would anything like this help, you could maybe route it to face down then it would be easier?
http://www.tyre-equipment.co.uk/acatalog/F...EX140_2d10
Well Spotted. Bow down Thumbs Up 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels.
Post #308142 Mon Aug 01 2011 9:44pm
barry15555
Then you could stick one of these on the end. http://www.ebay.co.uk/itm/Car-Motorcycle-T...20af9d0724
Post #308147 Mon Aug 01 2011 10:12pm
