![]() | Home > Maintenance & Modifications > Spare wheel pressure check |
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 ![]() ![]() ![]() |
I never even thought of this... Surely if you have a good relationship with your dealer they would do it for you gratis ??? Or maybe try kwik fit |
Come on - it only takes about 5 mins to lower and get the wheel out at home. Stick it in the back and check the pressures at the filling station or use a foot pump!!
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 ![]() ![]() |
Good idea... except that both are nearly 200 miles and 36 hours away. ![]() |
So no easier way then. Your reply seems to assume a youngish rather fit owner, none of which matches my profile sadly |
Hi OLDCRO. I did not assume nowt. I did my own and I'm 65; so with you in the seniors of he Forum. |
barry15555 Member Since: 09 Oct 2010 Location: Essex Posts: 187 ![]() ![]() ![]() |
Well Spotted. ![]() ![]() |
Then you could stick one of these on the end. http://www.ebay.co.uk/itm/Car-Motorcycle-T...20af9d0724
