Home > General > Tailgate out of alignment
santorini
2011 Range Rover Sport 3.0 TDV6 HSE Santorini Black
The tailgate on my MY11 sport is out of alignment. The upper part of the tailgate is out, I can put my fingers into the panel gap on the right hand side next to the right hand tail lamp but not on the left. The bottom of the tailgate (the main tailgate) is the opposite, I can fit fingers into left but not right.
Car went to dealers and they said they have adjusted it as much as possible but it's exactly the same as when it went in. Has anyone else had this problem? I can visibly see the upper split is out from a distance and it really bugs me now. I think panel gaps should be even on a £55k car...
Post #306144 Wed Jul 13 2011 10:18pm
ChrisP
They'll probably give you the same story I've had today "its within tolerance" it's great when they even add up tolerances on both sides of the problem so they can add them up to effectively come up with an overall tolerance of double.
I'm rapidly coming to the conclusion that if it comes out of the factory f Censored d its stays f Censored d because the dealers are incapable of actually fixing anything. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #306149 Wed Jul 13 2011 11:30pm
Bobby
There are certain measurements (with specific tolerances) to follow in adjusting the liftgate.
If they have done the adjustments accordingly and if you still find it out of alignment, then your RRS has an out of shape body! Shocked Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #306158 Thu Jul 14 2011 6:11am
santorini
Has yours got the same problem as mine?
Can other owners check their alignments on MY11 and let me know if yours is straight?
Post #306196 Thu Jul 14 2011 11:38am
SVR575
Santorini,this has bothered me since i collected mine, but it seems its only me that notices it. Its exactly as you say! SVR 2018 in Santorini Black.
Post #306202 Thu Jul 14 2011 12:57pm
AndyCh
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Mine's not great to be honest. The worst is trying to close the screen if I only open half the boot (which I like doing), but inevitably I'll get back in to find a "rear door not closed" warning on the dash.
Keep meaning to take it back to have it realigned, but it hardly sounds worth it!
Post #306220 Thu Jul 14 2011 4:44pm
ChrisP
Santorini,
No not the same as yours just a stream of similar issues which still haven't and seemingly won't be resolved as the issues are within tolerence i.e. they are now hiding shoddy quality by qualifying huge tolerances which might have been acceptable had I bought a Moskovitch 20 years ago,for example they are claiming +/- 10% on a rubber seal and as there are 2 involved the gap between the 2 can be +/- 20% as both are on their limits so error is additional so I've got a 5mm gap on something that should meet:bang: MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #306226 Thu Jul 14 2011 5:10pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
my upper tailgate is a pain too. The mis-alignment is not visibly noticeable but frequently the car thinks the upper tailgate is still open when it isn't. Also, the paintwork is slightly worn as a result. ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #306234 Thu Jul 14 2011 7:30pm
Here's another one for you all to check out except Autobiography models, looking at the back of your car see if your left hand side exhaust tail pipe is slightly lower that the right one, just about everyone i look at is the same from early models right upto 11 plate Mr. Green Things like this really bug me.
Post #306239 Thu Jul 14 2011 8:11pm
V8V Man
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
Yep, same here noticed it at the weekend. Must get down to dealer to discuss, but looking at comments so far I guess I can sense a fobbing off coming Sad MY2014 RRS Autobiography in Corris Grey, Black contrast roof and Cirrus interior, adaptive lights and side steps.
Gone - 2011 RRS HSE TDV6 Baltic Blue, Ivory/Ebony contrast stitching, Side steps, paddles, iPod/IPhone lead (works just fine with iPhone4), Adaptive lights
2011 Aston Martin V12 Vantage - Carbon Black Edition
Post #306243 Thu Jul 14 2011 8:21pm
mse
Just went out to mine - boot (both sections) perfectly aligned.
The top tailgate misslock, isnt an alignment issue im told - its all to do with the catch...mine occasionally suffers if i dont shut it hard enough Mike
2014 Facelift Discovery
Post #306251 Thu Jul 14 2011 8:35pm
SVR575
The opening rear tailgate window is a pain.Has to be slammed so hard it feels as if it will break. No wonder they have got rid of it now. SVR 2018 in Santorini Black.
Post #306253 Thu Jul 14 2011 8:38pm
mse
Your right there...still one of the best features of the current MY compared to the new Mike
Post #306255 Thu Jul 14 2011 8:45pm
AndyCh
Sort of gives some comfort that it isn't just mine. Are you guys all familiar with the answer Lotus owners get from dealers when something isn't quite right ......... TADTS!
I'm not sure I've seen anyone write it on here yet, but sounds like the top tailgate is certainly a case of TADTS.
Post #306298 Fri Jul 15 2011 10:18am
benson123
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
tailgate out of alighment
hi guys,
appreciate this is an old thread but if anyone has this issue i thought id share some info. if you remove the spoiler ( pretty easy only 5 fixings ) the 2 bolts which hold the glass hatch section of the tailgate are then easily accessible and actually on slotted holes, so you can loosen them slightly and move the hatch section up or down on either side. this will enable you to get a much better panel gap either side from the very top at the spoiler all the way down to the plastic boot section which is connected to the glass hatch. I had a massive gap one side ( whole finger width ) compared to a couple of millimeters on the other, and you could tell the spoiler was lower on one side compared to the other compared to the roof level. this solved it as it enabled me to push one side up which in turn equalled out the panel gaps. about 30 minutes from start to finish and makes a big difference to the appearance of the car ( to me anyway ).
cheers
Post #409354 Mon Jan 13 2014 6:33pm
