![]() | Home > General > Tailgate out of alignment |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
They'll probably give you the same story I've had today "its within tolerance" it's great when they even add up tolerances on both sides of the problem so they can add them up to effectively come up with an overall tolerance of double.
There are certain measurements (with specific tolerances) to follow in adjusting the liftgate.
santorini Member Since: 07 May 2011 Location: England Posts: 26 ![]() ![]() |
Has yours got the same problem as mine? Can other owners check their alignments on MY11 and let me know if yours is straight? |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
Santorini,this has bothered me since i collected mine, but it seems its only me that notices it. Its exactly as you say! SVR 2018 in Santorini Black. |
AndyCh Member Since: 23 Aug 2010 Location: UK Posts: 64 ![]() ![]() |
Mine's not great to be honest. The worst is trying to close the screen if I only open half the boot (which I like doing), but inevitably I'll get back in to find a "rear door not closed" warning on the dash.
Santorini,
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
my upper tailgate is a pain too. The mis-alignment is not visibly noticeable but frequently the car thinks the upper tailgate is still open when it isn't. Also, the paintwork is slightly worn as a result. ============
Here's another one for you all to check out except Autobiography models, looking at the back of your car see if your left hand side exhaust tail pipe is slightly lower that the right one, just about everyone i look at is the same from early models right upto 11 plate |
V8V Man Member Since: 12 Jan 2011 Location: Reading Posts: 65 ![]() ![]() ![]() |
Yep, same here noticed it at the weekend. Must get down to dealer to discuss, but looking at comments so far I guess I can sense a fobbing off coming |
Just went out to mine - boot (both sections) perfectly aligned.
The opening rear tailgate window is a pain.Has to be slammed so hard it feels as if it will break. No wonder they have got rid of it now. SVR 2018 in Santorini Black. |
Your right there...still one of the best features of the current MY compared to the new Mike 2014 Facelift Discovery |
Sort of gives some comfort that it isn't just mine. Are you guys all familiar with the answer Lotus owners get from dealers when something isn't quite right ......... TADTS!
benson123 Member Since: 13 Jan 2014 Location: United Kingdom Posts: 1 ![]() ![]() ![]() |
hi guys,
