![]() | Home > General > latest Mod |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
No you will have to power it. |
dcc Member Since: 23 Jun 2008 Location: Channel Islands Posts: 32 ![]() ![]() ![]() |
I have had this rearview camera system installed but I abandoned the number-plate camera in favour of one which is installed in the spoiler. The cable runs through the spoiler and follows the existing wiring that runs from the spoiler (for the rear light) into the inside of the vehicle. Hence nothing can be seen.
jamiequ1 Member Since: 23 Jan 2011 Location: london Posts: 58 ![]() |
FCC, sounds good , any chance of some pictures , where did you get the camara from?
Doe's anyone no of a camera that will go on the rear spoiler rather than the number plate light , i can only find very bulky ones , would rather one that didn't stand out as much. |
Sizzle TDV8 Member Since: 22 Mar 2010 Location: London Posts: 117 ![]() ![]() ![]() |
Maybe Ian from HIDs4U would be able to help........ Or even get his suppliers to start manufacturing one that can be cut into the trim where the rear washer is.....
I seem to remember Ian's is mounted inside the car. |
I got the camera from www.c-ko.co.uk/rvcameras.html. It is model CH-KR19 (with guidelines). As it fits under the spoiler the cable can be run through the existing cable ducting. Also it can be poistioned centrally. The following pictures may be useful. The one of the display shows the edge of the tailgate just visible at the bottom of the picture. The guidelines are very clear and the night-time picture is OK.
Nice one DCC , |
