Home > General > DIESEL FLAP WONT OPEN |
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 |
I think there is a manual ring pull in the boot. If you open the right hand side cover thingy you may find it there.
Mon Jul 04 2011 9:42am |
I found the rubber sucker cup used to change spot light bulbs worked a treat when my catch broke. RRS gone
Mon Jul 04 2011 10:10am |
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 |
I had a similar problem to this on mine. For me the problem was that there is a little black plastic bit on the flap that comes off sometimes. LR Engineering at it's finest. You can get the part at your dealer for peanuts and then it should be right as rain if your problem is the same. Without this bit there is nothing for the release mechanism to work against and open the flap.
Mon Jul 04 2011 11:02am |
A search would have brought you toTHIS file in my Gallery! Malaysia Boleh!
Mon Jul 04 2011 11:32am |
jrinns Member Since: 10 Dec 2010 Location: Midlands Posts: 88 |
When mine stuck , I pushed it in and pressed unlock on the keys. Seemed to work |
Mon Jul 04 2011 3:14pm |
Stephen Member Since: 15 Jun 2010 Location: West Sussex Posts: 30 |
I currently use my credit card to prise it open until the replacment rubber bit that helps it pop open arrives at my local dealer. |
Tue Jul 05 2011 11:33am |
V8KIP Member Since: 09 Dec 2010 Location: Kent Posts: 18 |
Mine used to do this, I used to have to lock/unlock using the keyfob to get it open. Then I sprayed the bit which releases with WD40 about 3 months ago and it hasn't done it since |
Tue Jul 05 2011 4:47pm |
Stealer#1 Member Since: 05 Jul 2011 Location: South Posts: 4 |
Just yank it open, apart from little ******* putting stuff in u can't get fuel out.... |
Tue Jul 05 2011 11:56pm |
