Home > General > DIESEL FLAP WONT OPEN
checkett
England 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Hi just gone to fill the car with diesel 2006 RRS and the flap on the car wont open.
Does anyone have any ideas what it could be and is there a manual way of opening the flap because im short on juice.
Thanks
Post #304897 Mon Jul 04 2011 9:39am
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
I think there is a manual ring pull in the boot. If you open the right hand side cover thingy you may find it there.
Thumbs Up Smile
Post #304898 Mon Jul 04 2011 9:42am
I found the rubber sucker cup used to change spot light bulbs worked a treat when my catch broke. RRS gone
Post #304900 Mon Jul 04 2011 10:10am
RRS_PAT
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I had a similar problem to this on mine. For me the problem was that there is a little black plastic bit on the flap that comes off sometimes. LR Engineering at it's finest. Whistle You can get the part at your dealer for peanuts and then it should be right as rain if your problem is the same. Without this bit there is nothing for the release mechanism to work against and open the flap.
Until then it is a real pain to open but can be done at the pump with perserverance Sad 2011 Autobiography Santorini Black
Post #304906 Mon Jul 04 2011 11:02am
Bobby
A search would have brought you toTHIS file in my Gallery! Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #304908 Mon Jul 04 2011 11:32am
jrinns
When mine stuck , I pushed it in and pressed unlock on the keys. Seemed to work
Post #304949 Mon Jul 04 2011 3:14pm
Stephen
I currently use my credit card to prise it open until the replacment rubber bit that helps it pop open arrives at my local dealer.
Post #305053 Tue Jul 05 2011 11:33am
V8KIP
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Mine used to do this, I used to have to lock/unlock using the keyfob to get it open. Then I sprayed the bit which releases with WD40 about 3 months ago and it hasn't done it since Wink
Post #305083 Tue Jul 05 2011 4:47pm
Stealer#1
Just yank it open, apart from little ******* putting stuff in u can't get fuel out....
Post #305129 Tue Jul 05 2011 11:56pm
