Home > General > Boot Liners
santorini
2011 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Boot Liners
Got my new sport coming on the weekend. Need a boot liner, any experience of these:
http://www.ukcustomcovers.com/products/lan...uct-search
or any better recommendations?
Also is the rubber boot mat worth buying, if so best place to buy?
Post #299314 Thu May 12 2011 10:25pm
mse
I have one.
Fantastic product - although i have been emailing shane as there is a minor fitting issue with mine - he has been very helpful so far
So i would recommend them, even if there is a problem (and i dont believe there will be) so far they have done more than many companies to fix it.
Quality wise is also very good. Im not 100% sure i like the boot side fitting process - but thats just me Mike
2014 Facelift Discovery
Post #299327 Thu May 12 2011 11:25pm
oldcro
Scotland
I have the rubber boot mat and am very pleased with it as it has a certain amount of grip so things don't slid about much. Never tried the liner so cannot compare it.
Post #299330 Thu May 12 2011 11:36pm
santorini
mse wrote:
I have one.
Thanks, what do you mean by boot side fitting process? What's the prob with it?
Post #299331 Thu May 12 2011 11:43pm
Stephen
I have one of these and the only problem I have had is that i can get the headrests off to put the D rings over the headrest mounts. I read the manual to look at the instructions for getting the headrest off and decided that you needed 4 hands to do this and have been unable to remove them. Think they are just stiff as it looks as though they have never been moved. Either that or i'm stupid....which is possible!!
Post #299369 Fri May 13 2011 12:34pm
There is a button that is flush with the surround on the headrest fitting opposite the button you use when raising of lowering the headrests. This button needs to be pressed in, it's fairly easy especially with a small screwdriver. 2005 Zambezi TDV6 - Gone but not forgotten
Post #299370 Fri May 13 2011 12:47pm
mse
What VA said - it took be 10 seconds to see it, and did it with my finger
From my reading the rear attachements - which hold the sides up fix to the body between the outer seal and the main body work - i didnt want to stick velcro there - the attachment then runs over the outside of the seal to fix to the velcro Mike
Post #299404 Fri May 13 2011 5:25pm
oldcro
Scotland
Thanks for that gem of information. No mention of another button to press in the handbook, I can now for the first time remove the headrests when folding the rear seats down.
Post #299444 Fri May 13 2011 10:46pm
Streaky
United Arab Emirates 2008 Range Rover Sport Supercharged Alaska White
Has anyone tried the rubber load bed liner from Britpart? Part number DA5555.
Whats the price of the Original OEM Land Rover item?
Thx.
S Ra-Ro Sport Super Dooper Charged.
Ford F350 Super Duty Prototype.
Ni$$@n Patrol 4.8 Overlander.
Post #299875 Wed May 18 2011 2:41pm
mse
britpart usually = s*itpart, so no sorry Mike
Post #299882 Wed May 18 2011 4:23pm
DAINEWBOY
Wales 2007 Range Rover Sport TDV6 HSE Zermatt Silver
i have been looking at this company to, that boot liner looks good covers everything RRS 07
VW POLO MK6
VW R32 MK5 GONE BUT NOT FORGOT
Post #299905 Wed May 18 2011 8:56pm
ChrisP
Just ordered one will post a review once its in. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #300042 Fri May 20 2011 12:47pm
mse
They are really good - Shane has helped resolve a minor issue very quickly.
I would be interested if you fit the rear tabs to the rain channel or not...i didnt want to, but i keep thinking maybe i should Mike
Post #300044 Fri May 20 2011 12:55pm
ChrisP
Fitted mine today,is it a perfect fit,no not really.
Is it good value for money,probably?
Will it do the job so I can just chuck my fishing tackle ,wet waders,wet boots and the dog in the back without worrying about ruining the rear cabin and getting anything soaking wet,definitely yes Thumbs Up MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #300631 Tue May 24 2011 6:32pm
mse
How did you find the fitting around the head rests?? mine is tight in that the spacing is a little off widthwise - it still works but the tabs arent straight Mike
Post #300644 Tue May 24 2011 9:20pm
