Home > General > Boot Liners |
santorini Member Since: 07 May 2011 Location: England Posts: 26 |
Got my new sport coming on the weekend. Need a boot liner, any experience of these:
Thu May 12 2011 9:25pm |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 |
I have the rubber boot mat and am very pleased with it as it has a certain amount of grip so things don't slid about much. Never tried the liner so cannot compare it. |
Thu May 12 2011 10:36pm |
Thanks, what do you mean by boot side fitting process? What's the prob with it? |
Thu May 12 2011 10:43pm |
Stephen Member Since: 15 Jun 2010 Location: West Sussex Posts: 30 |
I have one of these and the only problem I have had is that i can get the headrests off to put the D rings over the headrest mounts. I read the manual to look at the instructions for getting the headrest off and decided that you needed 4 hands to do this and have been unable to remove them. Think they are just stiff as it looks as though they have never been moved. Either that or i'm stupid....which is possible!! |
Fri May 13 2011 11:34am |
There is a button that is flush with the surround on the headrest fitting opposite the button you use when raising of lowering the headrests. This button needs to be pressed in, it's fairly easy especially with a small screwdriver. 2005 Zambezi TDV6 - Gone but not forgotten
Fri May 13 2011 11:47am |
What VA said - it took be 10 seconds to see it, and did it with my finger
From my reading the rear attachements - which hold the sides up fix to the body between the outer seal and the main body work - i didnt want to stick velcro there - the attachment then runs over the outside of the seal to fix to the velcro Mike 2014 Facelift Discovery |
Fri May 13 2011 4:25pm |
Thanks for that gem of information. No mention of another button to press in the handbook, I can now for the first time remove the headrests when folding the rear seats down. |
Fri May 13 2011 9:46pm |
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 |
Has anyone tried the rubber load bed liner from Britpart? Part number DA5555.
Wed May 18 2011 1:41pm |
britpart usually = s*itpart, so no sorry Mike
Wed May 18 2011 3:23pm |
DAINEWBOY Member Since: 10 May 2011 Location: Aberdare Posts: 50 |
i have been looking at this company to, that boot liner looks good covers everything RRS 07
Wed May 18 2011 7:56pm |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 |
Just ordered one will post a review once its in. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Fri May 20 2011 11:47am |
They are really good - Shane has helped resolve a minor issue very quickly.
Fri May 20 2011 11:55am |
Tue May 24 2011 5:32pm |
How did you find the fitting around the head rests?? mine is tight in that the spacing is a little off widthwise - it still works but the tabs arent straight Mike
Tue May 24 2011 8:20pm |
