![]() | Home > General > Boot Liners |
santorini Member Since: 07 May 2011 Location: England Posts: 26 ![]() ![]() |
Got my new sport coming on the weekend. Need a boot liner, any experience of these:
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 ![]() ![]() |
I have the rubber boot mat and am very pleased with it as it has a certain amount of grip so things don't slid about much. Never tried the liner so cannot compare it. |
Thanks, what do you mean by boot side fitting process? What's the prob with it? |
Stephen Member Since: 15 Jun 2010 Location: West Sussex Posts: 30 ![]() ![]() ![]() |
I have one of these and the only problem I have had is that i can get the headrests off to put the D rings over the headrest mounts. I read the manual to look at the instructions for getting the headrest off and decided that you needed 4 hands to do this and have been unable to remove them. Think they are just stiff as it looks as though they have never been moved. Either that or i'm stupid....which is possible!! |
There is a button that is flush with the surround on the headrest fitting opposite the button you use when raising of lowering the headrests. This button needs to be pressed in, it's fairly easy especially with a small screwdriver. 2005 Zambezi TDV6 - Gone but not forgotten
What VA said - it took be 10 seconds to see it, and did it with my finger
From my reading the rear attachements - which hold the sides up fix to the body between the outer seal and the main body work - i didnt want to stick velcro there - the attachment then runs over the outside of the seal to fix to the velcro Mike 2014 Facelift Discovery |
Thanks for that gem of information. No mention of another button to press in the handbook, I can now for the first time remove the headrests when folding the rear seats down. |
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 ![]() ![]() ![]() |
Has anyone tried the rubber load bed liner from Britpart? Part number DA5555.
britpart usually = s*itpart, so no sorry Mike
DAINEWBOY Member Since: 10 May 2011 Location: Aberdare Posts: 50 ![]() ![]() ![]() |
i have been looking at this company to, that boot liner looks good covers everything RRS 07
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
Just ordered one will post a review once its in. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
They are really good - Shane has helped resolve a minor issue very quickly.
Fitted mine today,is it a perfect fit,no not really. Is it good value for money,probably? Will it do the job so I can just chuck my fishing tackle ,wet waders,wet boots and the dog in the back without worrying about ruining the rear cabin and getting anything soaking wet,definitely yes ![]() Audi A5 Sportback Black Edition 3.0 tdi quattro S Line |
How did you find the fitting around the head rests?? mine is tight in that the spacing is a little off widthwise - it still works but the tabs arent straight Mike
