![]() | Home > Maintenance & Modifications > Success |
scott7 Member Since: 20 Apr 2009 Location: Scotland Posts: 282 ![]() ![]() |
I've had three sets in mine, noise returns after a few thousand miles.
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
For 9 quid and 1 hour of my time if I get a few thousand miles i'll be happy |
dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212 ![]() ![]() ![]() |
uk guy on here as had them fitted |
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 ![]() ![]() ![]() |
Yep... I had polybush Front & back fitted. So far it's been perfect.
tigers111 Member Since: 16 Apr 2011 Location: fife Posts: 70 ![]() ![]() ![]() |
just had mine replaced by land rover through the warranty but if these go quite regularly i will look at the poly bushes, where did you get them from and how much were they |
Cheers fellas,the fact that polybushes seem to work goes towards confirming my suspicions. |
barry15555 Member Since: 09 Oct 2010 Location: Essex Posts: 187 ![]() ![]() ![]() |
Try Here. http://www.polybush.co.uk/ ![]() ![]() |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
I had them fitted to mine a couple of months ago only on the front, the ride and taughtness is improved, the only problem is I now have a knocking coming from the n/s front. Had a look and there is play in lower ball joint. Question: do you replace just the lower ball joint or the whole arm? All of this on a car that has only done 26K |
I've just replaced both lower ball joints,my mate got me mine both for £34. :thumbsup:If you replace the wishbones you will have to have the alignment done aswell.I used a ball joint press and did it on the car. |
I had mine fitted by md motors in willenhall in the west midlands. 1 hour front and about the same on the back.
Yes the polybushes on the front are a tight fit, so much so that we had to use clamps to pull the brackets in place before bolting up. I will get my garage to replace just the ball joint and not the arm, thanks for the advice.. |
Benidorm Mick Member Since: 27 May 2010 Location: Wiltshire Posts: 102 ![]() ![]() |
So how easy were they to fit my good man? I'm not a total cretin but i'm no James May either. Been mentally blanking out the knocking for a couple of years now ![]() |
There you go....
Glad you posted that,because it confirms what I thought could be the only thing that could knock,just a design flaw that can be easily rectified permanetly |
