Home > Maintenance & Modifications > Success |
scott7 Member Since: 20 Apr 2009 Location: Scotland Posts: 282 |
I've had three sets in mine, noise returns after a few thousand miles.
Sat May 14 2011 6:47pm |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 |
For 9 quid and 1 hour of my time if I get a few thousand miles i'll be happy Has anyone had the polybushes fitted instead of the rubber ones? |
Sat May 14 2011 8:11pm |
dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212 |
uk guy on here as had them fitted |
Sun May 15 2011 5:41pm |
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 |
Yep... I had polybush Front & back fitted. So far it's been perfect.
Mon May 16 2011 5:42pm |
tigers111 Member Since: 16 Apr 2011 Location: fife Posts: 70 |
just had mine replaced by land rover through the warranty but if these go quite regularly i will look at the poly bushes, where did you get them from and how much were they |
Mon May 16 2011 5:49pm |
Cheers fellas,the fact that polybushes seem to work goes towards confirming my suspicions. |
Mon May 16 2011 5:53pm |
barry15555 Member Since: 09 Oct 2010 Location: Essex Posts: 187 |
Try Here. http://www.polybush.co.uk/ 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels. |
Mon May 16 2011 7:09pm |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
I had them fitted to mine a couple of months ago only on the front, the ride and taughtness is improved, the only problem is I now have a knocking coming from the n/s front. Had a look and there is play in lower ball joint. Question: do you replace just the lower ball joint or the whole arm? All of this on a car that has only done 26K |
Tue May 17 2011 7:48am |
I've just replaced both lower ball joints,my mate got me mine both for £34. :thumbsup:If you replace the wishbones you will have to have the alignment done aswell.I used a ball joint press and did it on the car. |
Tue May 17 2011 4:42pm |
I had mine fitted by md motors in willenhall in the west midlands. 1 hour front and about the same on the back.
Wed May 18 2011 6:04pm |
Yes the polybushes on the front are a tight fit, so much so that we had to use clamps to pull the brackets in place before bolting up. I will get my garage to replace just the ball joint and not the arm, thanks for the advice.. |
Wed May 18 2011 10:08pm |
Benidorm Mick Member Since: 27 May 2010 Location: Wiltshire Posts: 102 |
So how easy were they to fit my good man? I'm not a total cretin but i'm no James May either. Been mentally blanking out the knocking for a couple of years now |
Thu May 19 2011 8:31am |
There you go....
Thu May 19 2011 8:08pm |
Glad you posted that,because it confirms what I thought could be the only thing that could knock,just a design flaw that can be easily rectified permanetly |
Thu May 19 2011 9:09pm |
