Home > Maintenance & Modifications > Success
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Success
No more knocking Very Happy Swapped the ARB bushes this afternoon,they looked fine and seemed no play in them,but it was another thing to tick off the list.Best £9 I ever spent. Thumbs Up
Post #299473 Sat May 14 2011 2:52pm
scott7
Scotland
I've had three sets in mine, noise returns after a few thousand miles.
Hope you have more luck with yours.
Post #299486 Sat May 14 2011 6:47pm
mrfixit
For 9 quid and 1 hour of my time if I get a few thousand miles i'll be happy Wink Has anyone had the polybushes fitted instead of the rubber ones?
Post #299491 Sat May 14 2011 8:11pm
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
uk guy on here as had them fitted
Post #299538 Sun May 15 2011 5:41pm
UK Guy
England 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Yep... I had polybush Front & back fitted. So far it's been perfect.
Done about 7k on them and no knocking at all.
Let's hope it stays that way!!! RRS HSE with a few extras & a
2013 RRS Autobiography
Post #299659 Mon May 16 2011 5:42pm
tigers111
United Kingdom 2006 Range Rover Sport TDV6 HSE Santorini Black
just had mine replaced by land rover through the warranty but if these go quite regularly i will look at the poly bushes, where did you get them from and how much were they
Post #299661 Mon May 16 2011 5:49pm
mrfixit
Cheers fellas,the fact that polybushes seem to work goes towards confirming my suspicions.
Post #299663 Mon May 16 2011 5:53pm
barry15555
England 2006 Range Rover Sport Supercharged Bonatti Grey
DRDILL wrote:
could some one post a link as to where we can get these poly bushes, and where they go and how easy to fit. I would like to change mine if possible.
Try Here. http://www.polybush.co.uk/ Thumbs Up Thumbs Up 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels.
Post #299676 Mon May 16 2011 7:09pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
I had them fitted to mine a couple of months ago only on the front, the ride and taughtness is improved, the only problem is I now have a knocking coming from the n/s front. Had a look and there is play in lower ball joint. Question: do you replace just the lower ball joint or the whole arm? All of this on a car that has only done 26K Rolling Eyes
Post #299718 Tue May 17 2011 7:48am
mrfixit
I've just replaced both lower ball joints,my mate got me mine both for £34. :thumbsup:If you replace the wishbones you will have to have the alignment done aswell.I used a ball joint press and did it on the car.
Post #299780 Tue May 17 2011 4:42pm
UK Guy
I had mine fitted by md motors in willenhall in the west midlands. 1 hour front and about the same on the back.
Tech did advise me to replace the ball joints and down links (something like that) at the same time which I had done.
Which only took am extra hour or so I think it was.
One thing to note if your going to fit the polybush Arb bushes yourself... The fronts I was told are a very tight fit getting clamp on. Lot more meat on them I think. RRS HSE with a few extras & a
Post #299893 Wed May 18 2011 6:04pm
1JBS
Yes the polybushes on the front are a tight fit, so much so that we had to use clamps to pull the brackets in place before bolting up. I will get my garage to replace just the ball joint and not the arm, thanks for the advice.. Thumbs Up
Post #299920 Wed May 18 2011 10:08pm
Benidorm Mick
2008 Range Rover Sport TDV8 HSE Stornoway Grey
Re: Success
So how easy were they to fit my good man? I'm not a total cretin but i'm no James May either. Been mentally blanking out the knocking for a couple of years now Embarassed
Post #299933 Thu May 19 2011 8:31am
UK Guy
There you go....
The instructions for the front are for the packers... If you were to change the Arb with polybush you would not need them
Instead of inserting packer you replace the complete bush.
Disco and rrs are the same.
Front. Arb http://www.disco3.co.uk/forum/topic30622.html
Back Arb http://www.disco3.co.uk/forum/topic51384.h...shes%5C%22 RRS HSE with a few extras & a
Post #299977 Thu May 19 2011 8:08pm
mrfixit
Glad you posted that,because it confirms what I thought could be the only thing that could knock,just a design flaw that can be easily rectified permanetly Thumbs Up
Post #299983 Thu May 19 2011 9:09pm
