Home > Maintenance & Modifications > 22" pressure question
lilweliwell
Ireland 2005 Range Rover Sport TDV6 HSE Alaska White
Hi, I have found this on Bridgestone web:
"Contrary to popular belief, tyre pressure is not determined by the type of tyre or its size but
upon your vehicle's load and driving application i.e. speed"
Is that correct? BCS.I was told by the man from garage that i should have 290 kPa both front and rear. But in the manual is that front should by 230kPa and back 250kPa. So what is correct. I am wearing Hankook 285/35/R22 106W.
Thanks guys
Post #298976 Tue May 10 2011 11:09pm
I'm running 250 k Pa (36psi) nitrogen in mine.
I agree the book says 42psi but that sounds excessive and would also rattle your teeth out! RRS gone
Post #299027 Wed May 11 2011 12:08pm
gilford
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
NITROGEN Shocked
Care to elaborate...............
Post #299029 Wed May 11 2011 12:32pm
Jonny Fresh
NITROGEN Shocked
Laughing Not this again.......
Bit of a gimmick really seen as air is 79% nitrogen anyway.............the theory is the air pressure fluctuates less with temperature change due to there being less moisture in 100% nitrogen.....
Unless you have an F1 car you won't notice any difference
Post #299030 Wed May 11 2011 12:38pm
gilford
I was thinking more along the lines of where would you get it from, I've not seen it in my local Shell garage Rolling with laughter
Post #299043 Wed May 11 2011 12:54pm
Jonny Fresh
Some tyre places do it.....
Post #299047 Wed May 11 2011 12:56pm
Yes a bit of a gimmick.. but the lower pressure loss over time compared to normal air sold it to me...(I hate checking tyre pressures)
Kwik Fit now offer a nitrogen filling service.
plus I was told it is less corrosive than normal air but I'm not so sure now... Mr. Green RRS gone
Post #299057 Wed May 11 2011 1:34pm
gilford
So, back to the OP's question..........
36 PSI you say? I'm sure I was told to run 42?
Post #299076 Wed May 11 2011 3:46pm
I've heard the number 42 being bounced around also...
The garage told me "use the same pressures as the 20's" which was 32 on my Disco... I've increased to 36 after the alloy failures (to give more side wall stiffness/protection) and the ride is certainly much firmer as a result.
Are you running 42 psi on yours then? RRS gone
Post #299079 Wed May 11 2011 3:52pm
gilford
I think so, cant remember what I put in to be honest! The car is in the Dealer at the moment but will check tomorrow Confused
Post #299083 Wed May 11 2011 4:14pm
lilweliwell
Right now i have exactly what is book saying...but still not sure what should be...i have found couple treads and getting confused now...
1 / Overfinch saying 37psi front 40psi back (what is more compare to manual),
2 / tyre brands like Michelin and Bridgestone saying it's not about tyre size or value of air, but about pressure - it means any size same pressure - doesn't matter how big is your tyre...
3 /And on the third hand i found treads saying add 4PSI extra compare to manual.
Only what I found for sure right is that there must be difference between front and rear bcs. engine is in front...but that's it...
The other question is, handbook manual contains press. for cold tyres...My tyres will heat up enough after 5 min driving...So even if I take pressure of cold tyre and than drive to nearst petrol station with air...they are hot and I can only guess how much air to put Laughing
It make sence that the pressure must be same for all sizes...but as I followed this, when tyres are cold they doesn't look there is enough pressure....when I had 290kPa allround car was bumpy...
So now I am not smarter than before...I think i'll do some tests with different tyres pressures and keep the best one...
Post #299094 Wed May 11 2011 5:32pm
drdelrrs
Keep close to manufacturer's stated pressures as its the law and an offence not to have correctly inflated tyres. Cops will measure them if you're involved in a prang and insurers can wriggle.
- I've forgotten the margin but I thinks it 10% !!
Post #299101 Wed May 11 2011 5:53pm
zot1985
United Kingdom 2005 Range Rover Sport Supercharged Santorini Black
I personaly run 40 psi front and 42 psi back, i noticed car slides abit in wet compare to 36 psi it use to have, but i dnt suffer from teeth ratle as some say...
Post #299131 Wed May 11 2011 9:11pm
lilweliwell
Now I have 37psi front and 40 back...i think ride is more firm so propably i will go back to pressures from manual what i found as more comfortable
Post #299389 Fri May 13 2011 3:50pm
