![]() | Home > Maintenance & Modifications > 22" pressure question |
lilweliwell Member Since: 27 Nov 2010 Location: Dublin Posts: 20 ![]() ![]() ![]() |
Hi, I have found this on Bridgestone web:
I'm running 250 k Pa (36psi) nitrogen in mine.
gilford Member Since: 07 Jan 2010 Location: Anglesey Posts: 542 ![]() ![]() ![]() |
NITROGEN ![]() Care to elaborate............... |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
![]() Bit of a gimmick really seen as air is 79% nitrogen anyway.............the theory is the air pressure fluctuates less with temperature change due to there being less moisture in 100% nitrogen..... Unless you have an F1 car you won't notice any difference |
I was thinking more along the lines of where would you get it from, I've not seen it in my local Shell garage |
Some tyre places do it..... |
Yes a bit of a gimmick.. but the lower pressure loss over time compared to normal air sold it to me...(I hate checking tyre pressures)
So, back to the OP's question..........
I've heard the number 42 being bounced around also...
I think so, cant remember what I put in to be honest! The car is in the Dealer at the moment but will check tomorrow |
Right now i have exactly what is book saying...but still not sure what should be...i have found couple treads and getting confused now...
zot1985 Member Since: 31 Mar 2011 Location: bury Posts: 40 ![]() ![]() ![]() |
I personaly run 40 psi front and 42 psi back, i noticed car slides abit in wet compare to 36 psi it use to have, but i dnt suffer from teeth ratle as some say... |
Now I have 37psi front and 40 back...i think ride is more firm so propably i will go back to pressures from manual what i found as more comfortable |
