Home > Maintenance & Modifications > 22" pressure question |
lilweliwell Member Since: 27 Nov 2010 Location: Dublin Posts: 20 |
Hi, I have found this on Bridgestone web:
Tue May 10 2011 10:09pm |
I'm running 250 k Pa (36psi) nitrogen in mine.
Wed May 11 2011 11:08am |
gilford Member Since: 07 Jan 2010 Location: Anglesey Posts: 542 |
NITROGEN Care to elaborate............... |
Wed May 11 2011 11:32am |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
Not this again....... Bit of a gimmick really seen as air is 79% nitrogen anyway.............the theory is the air pressure fluctuates less with temperature change due to there being less moisture in 100% nitrogen..... Unless you have an F1 car you won't notice any difference |
Wed May 11 2011 11:38am |
I was thinking more along the lines of where would you get it from, I've not seen it in my local Shell garage |
Wed May 11 2011 11:54am |
Some tyre places do it..... |
Wed May 11 2011 11:56am |
Yes a bit of a gimmick.. but the lower pressure loss over time compared to normal air sold it to me...(I hate checking tyre pressures)
Wed May 11 2011 12:34pm |
So, back to the OP's question..........
Wed May 11 2011 2:46pm |
I've heard the number 42 being bounced around also...
Wed May 11 2011 2:52pm |
I think so, cant remember what I put in to be honest! The car is in the Dealer at the moment but will check tomorrow |
Wed May 11 2011 3:14pm |
Right now i have exactly what is book saying...but still not sure what should be...i have found couple treads and getting confused now...
Wed May 11 2011 4:32pm |
zot1985 Member Since: 31 Mar 2011 Location: bury Posts: 40 |
I personaly run 40 psi front and 42 psi back, i noticed car slides abit in wet compare to 36 psi it use to have, but i dnt suffer from teeth ratle as some say... |
Wed May 11 2011 8:11pm |
Now I have 37psi front and 40 back...i think ride is more firm so propably i will go back to pressures from manual what i found as more comfortable |
Fri May 13 2011 2:50pm |
