Home > Technical > Brake Pads..is this normal??? |
No not normal at all. 50k miles and only one change of pads, probably due though. 2005 Zambezi TDV6 - Gone but not forgotten
Fri May 06 2011 10:19am |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Definately not normal. I'd be asking the dealer for an explanation as to why they think it is? 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Fri May 06 2011 10:30am |
lauretta29 Member Since: 06 May 2011 Location: Borehamwood Posts: 6 |
they have put the car on the diagnostic machine and said there was no fault!!! My husband has demanded that they take all the wheels off and check the car the "old fashioned" way! Land Rover have said that it is to be expected of this car, as it is heavy on the brakes?? |
Fri May 06 2011 10:35am |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
I had the same problem with my "S" at 18,000 miles needed new handrake shoes, new rear discs due to handbrake sticking on and new front pads all rather disappointing. |
Fri May 06 2011 10:42am |
Sorry but that's a load of bull t!, sounds like a fob off to me! My current RRS has about 24k on the clock and the brakes are fine. My 1st set of tyres were replaced at 20k but they were still well within legal limits and probably had another 4 k of life in them at the time. My previous RRS (2007 model) had one set of pads replaced in a 2 1/2 year period and also one set of tyres. That car was mine from new and was sold with about 47k on the clock. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black |
Fri May 06 2011 10:48am |
JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113 |
I have a 2008 TDV6 with 25,000 miles on the clock, I prefer to do most of the service work myself for two reasons, 1. to keep the cost down when it goes in for the required service and 2. because I know the work has been done properly if I do it myself.
Fri May 06 2011 11:06am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Sounds like something is binding, whats your MPG like ? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Fri May 06 2011 11:07am |
my average is 21mpg |
Fri May 06 2011 11:26am |
MPG is a bit low but if it's mostly urban then that could be the reason. Take it to another dealer. 2005 Zambezi TDV6 - Gone but not forgotten
Fri May 06 2011 11:37am |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 |
Check your MAP sensors! |
Fri May 06 2011 11:41am |
Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434 |
You're being fobbed off mate - my beutie has 66000 miles on and has had 1 change of brakes (although the next is imminent!
Fri May 06 2011 8:41pm |
ok....update on my car. Apparently, the car has now had a full inspection and there is "nothing wrong with it". However, just spoke to another Land Rover dealer who said he and his workshop foreman had never heard anything like it. The garage that it's at wants to charge me £295 for changing the rear pads-think they are taking me for a ride. What do i do? Is there a motor association I can call to help me????? Need some top advice!!! |
Mon May 09 2011 5:39pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 |
£295 just for rear pads? get it out of there and go some where else. SVR 2018 in Santorini Black. |
Mon May 09 2011 5:51pm |
If the works not done, then take it.
Mon May 09 2011 6:05pm |
