Home > Technical > Brake Pads..is this normal???
lauretta29
2009 Range Rover Sport TDV6 S Alaska White
Hi, my Range Rover Sport 2009 has been picked up by Land Rover Assistance and is currently at the Land Rover Garage. My brake pad warning light has come on again. The garage have said that I need another set of rear pads. This will be my 3rd set of rears in 2 years and my fronts are already on their 3rd set. I have only done 19000 miles and use the car for local journeys only. I have also had two full sets of tyres in the same time. Do you think this is normal???
Post #298288 Fri May 06 2011 11:04am
No not normal at all. 50k miles and only one change of pads, probably due though. 2005 Zambezi TDV6 - Gone but not forgotten
Post #298290 Fri May 06 2011 11:19am
Endjin
Scotland
Definately not normal. I'd be asking the dealer for an explanation as to why they think it is? 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #298293 Fri May 06 2011 11:30am
lauretta29
they have put the car on the diagnostic machine and said there was no fault!!! My husband has demanded that they take all the wheels off and check the car the "old fashioned" way! Land Rover have said that it is to be expected of this car, as it is heavy on the brakes??
Post #298294 Fri May 06 2011 11:35am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
I had the same problem with my "S" at 18,000 miles needed new handrake shoes, new rear discs due to handbrake sticking on and new front pads all rather disappointing.
Post #298296 Fri May 06 2011 11:42am
Endjin
Scotland
Sorry but that's a load of bull Censored t!, sounds like a fob off to me! My current RRS has about 24k on the clock and the brakes are fine. My 1st set of tyres were replaced at 20k but they were still well within legal limits and probably had another 4 k of life in them at the time. My previous RRS (2007 model) had one set of pads replaced in a 2 1/2 year period and also one set of tyres. That car was mine from new and was sold with about 47k on the clock. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Post #298298 Fri May 06 2011 11:48am
JimboTD5
England 2008 Range Rover Sport TDV6 S Buckingham Blue
I have a 2008 TDV6 with 25,000 miles on the clock, I prefer to do most of the service work myself for two reasons, 1. to keep the cost down when it goes in for the required service and 2. because I know the work has been done properly if I do it myself.
This week I changed the front and rear pads and adjusted the EPB, the pads were only about 60% worn when compared to the new genuine parts and disc wear was minimal, this was the first time the brakes had been changed.
I also tow a very large twin axle caravan which I would expect to put more strain on the braking system!
I can't imagine why you should be having so much wear on your brakes unless they are in contact with the disc slightly more than they should be, then the wheels would run hot and your fuel consumption would be high!
I will be very interested to hear what the cause of the problem is, good luck.
Jim
Post #298302 Fri May 06 2011 12:06pm
SRE
Spain
Sounds like something is binding, whats your MPG like ? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #298305 Fri May 06 2011 12:07pm
lauretta29
my average is 21mpg
Post #298315 Fri May 06 2011 12:26pm
MPG is a bit low but if it's mostly urban then that could be the reason. Take it to another dealer. 2005 Zambezi TDV6 - Gone but not forgotten
Post #298318 Fri May 06 2011 12:37pm
DSL
Check your MAP sensors! Whistle
Post #298320 Fri May 06 2011 12:41pm
Jonathan
England 2012 Range Rover Sport SDV6 Autobiography Fuji White
You're being fobbed off mate - my beutie has 66000 miles on and has had 1 change of brakes (although the next is imminent!
Sorry to not be able to offer anything more constructive - if you want sympathy then ask me how many times I have had my bushes changed.....And now they are saying theyre not covered under the extended LR warranty - very funny...not. Jaguar XKR Convertible
MY 2012 Range Rover Sport TDV6 Autobiography in Fujian White....Mmmmmmm
Range Rover Evoque 2.2 Prestige in white - gone
Porsche Boxster S White with lots of extras! Gone
Lotus Elise 2011 Touring for sunny days - gone!
Previously....
RRS TDV8 Black 57 Plate
645ci
Jag XKR Convertible (my wife still loves this car!)
BMW 530i
BMW 328i (I loved this car)
Golf R32
Post #298393 Fri May 06 2011 9:41pm
lauretta29
ok....update on my car. Apparently, the car has now had a full inspection and there is "nothing wrong with it". However, just spoke to another Land Rover dealer who said he and his workshop foreman had never heard anything like it. The garage that it's at wants to charge me £295 for changing the rear pads-think they are taking me for a ride. What do i do? Is there a motor association I can call to help me????? Need some top advice!!!
Post #298793 Mon May 09 2011 6:39pm
SVR575
£295 just for rear pads? get it out of there and go some where else. SVR 2018 in Santorini Black.
Post #298794 Mon May 09 2011 6:51pm
mse
If the works not done, then take it.
If the works been done - did you approve it - if not then its there fault, seek advice and take the car back
If the works been done and you did approve it - ask for the removed parts and never return Mike
2014 Facelift Discovery
Post #298799 Mon May 09 2011 7:05pm
