Home > General > Fuel range.... according to the LED display.
Streaky
United Arab Emirates 2008 Range Rover Sport Supercharged Alaska White
When I go to the petrol station to fill up my 2008 RRS SC it's common practice not to switch off the engine and let the pump attendant do his job. After all.... it's hot and i want to stay inside with the air conditioning!
I notice that when the tank slowly fills up the LED 'Range' will only read up to 350km for a full tank.
However....when I occasionally switch off the engine and then fill up.... the LED range indicator reads in the regeon of 430-450km per full tank.
Why is that? Surely a 'full' tank is a 'full' tank.
Curious.......
Post #297300 Tue Apr 26 2011 7:44am
mse
I first thought you had to turn the engine off Shocked especially to let the air settle in the tank - which probably explains the reading.
On mine only resetting it gets it to recalculate... Mike
2014 Facelift Discovery
Post #297308 Tue Apr 26 2011 8:34am
Mine changes everytime i fill it up, i think it calculates based on the current average mpg you have just been doing, ive just filled mine up again for the second time this week £120 of V Power Thumbs Up
Post #297510 Wed Apr 27 2011 7:56pm
mse
Is V-Power noticable on the sport...i always use Shell std fuel as i can tell the difference between supermarket and shell. Mike
Post #297526 Wed Apr 27 2011 10:15pm
Ive no idea if its any better or not, i guess it must be, its like would you put cheap oil in your engine? Errr no, thats why i always put a decent fuel in my motors Thumbs Up
Post #297543 Thu Apr 28 2011 7:05am
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
It is a higher octane of fuel (97 RON or so compared to the Standard of 95), you will probably find that in your owners manual etc i recommends to use the higher octane fuel. If this is the case then the car's map will be designed around a fuel of a higher octane than that of the fuel you are currently using which will be causing a reduction in power...some extreme cases it can cause "pinking".
Post #297544 Thu Apr 28 2011 7:14am
mse
I might try v-power, see how it goes - like i said, i agree the difference between supermarket (cheap one) and shell better quality...but v-power has always seemed one step too far! Mike
Post #297560 Thu Apr 28 2011 8:56am
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Never mind that, go on depress us..............how much to fill your tank ??? L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #297570 Thu Apr 28 2011 10:28am
Streaky
It would be more expensive to fill the tank with water...seriously!
No more than thirty quid from empty to the brim. Ra-Ro Sport Super Dooper Charged.
Ford F350 Super Duty Prototype.
Ni$$@n Patrol 4.8 Overlander.
Post #297591 Thu Apr 28 2011 12:45pm
will_wonka
Big Cry Big Cry Big Cry Big Cry L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #297597 Thu Apr 28 2011 1:04pm
Streaky
The flip side of the coin is that the Range Rover Sports value goes down quicker here than anywhere else in the world.
Last year I paid 29,000 pounds for my 2008 RRS SC. After 8 months the car is now worth only 23,000 pounds.
Next year it will be around 18k. Ra-Ro Sport Super Dooper Charged.
Post #297601 Thu Apr 28 2011 1:38pm
will_wonka
Shocked
.....but who cares when you can fill her gusset to the brim for only 30 British Exclamation Wink L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #297620 Thu Apr 28 2011 5:54pm
Streaky
I've done some research on this and found that the expected fuel 'Range' number is an estimation calculated by the previous tank full of fuel.
So if you drive with a lead foot the 'Range' figure will be quite low when you next visit the pump.
If you take it easier at the lights and don't race through the box you'll see a much higher number on the expected fuel range display after the next top up.
Basicly the car is learning about the way you drive..... now ain't that clever for an English car! Ra-Ro Sport Super Dooper Charged.
Post #301858 Sun Jun 05 2011 8:50am
bigdave
i never look at my dte on the dash, there not accurate any ways
Post #302096 Mon Jun 06 2011 10:37pm
Steuart64
Scotland 2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Was at the LRE in Dunkeld on Friday and the staff all recommend premium diesel. One girl used to work at a fuel provider and stated that as well as better performance, cleaner engine, reduced emissions you can expect at least 24 miles extra to the tank. Doesnt seem much but at 22mpg around town its a big saving. Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill
Ex - Audi A4 Cab 3.0TDi Quattro
Ex - Freelander2 SE TD4
Ex - CRV Auto
Post #302149 Tue Jun 07 2011 1:09pm
