![]() | Home > General > Fuel range.... according to the LED display. |
I first thought you had to turn the engine off |
Mine changes everytime i fill it up, i think it calculates based on the current average mpg you have just been doing, ive just filled mine up again for the second time this week £120 of V Power |
Is V-Power noticable on the sport...i always use Shell std fuel as i can tell the difference between supermarket and shell. Mike
Ive no idea if its any better or not, i guess it must be, its like would you put cheap oil in your engine? Errr no, thats why i always put a decent fuel in my motors |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
It is a higher octane of fuel (97 RON or so compared to the Standard of 95), you will probably find that in your owners manual etc i recommends to use the higher octane fuel. If this is the case then the car's map will be designed around a fuel of a higher octane than that of the fuel you are currently using which will be causing a reduction in power...some extreme cases it can cause "pinking". |
I might try v-power, see how it goes - like i said, i agree the difference between supermarket (cheap one) and shell better quality...but v-power has always seemed one step too far! Mike
Never mind that, go on depress us..............how much to fill your tank ??? L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 ![]() ![]() ![]() |
It would be more expensive to fill the tank with water...seriously!
The flip side of the coin is that the Range Rover Sports value goes down quicker here than anywhere else in the world.
I've done some research on this and found that the expected fuel 'Range' number is an estimation calculated by the previous tank full of fuel.
bigdave Member Since: 09 May 2011 Location: liverpool Posts: 8 ![]() ![]() ![]() |
i never look at my dte on the dash, there not accurate any ways |
Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539 ![]() ![]() ![]() |
Was at the LRE in Dunkeld on Friday and the staff all recommend premium diesel. One girl used to work at a fuel provider and stated that as well as better performance, cleaner engine, reduced emissions you can expect at least 24 miles extra to the tank. Doesnt seem much but at 22mpg around town its a big saving. Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
