![]() | Home > Technical > How's your MAP sensor? |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
If you want to join in the fun have a look at http://www.disco3.co.uk/forum/topic64159.html if you've got a TDV6 lump. It easy to check, if I can do it a blind monkey with a severe hangover can do it. |
It had to happen at some stage!! |
BUMP!!
Ok then i'll get my hands dirty if i really have to |
You'll enjoy the experience!! Pics please. |
Oh bo11ocks, i forgot to look today, been using the wifes motor, maybe tomorrow after ive been to malham in the dales |
Ok so i took my map sensor out today, it was a little dirty but nothing like the pic above, cleaned it up inside and out and put back together, thanks for the heads up on cleaning though, |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 ![]() ![]() |
Cleaned mine today, fairly heavily soiled and you could not see the hole into the sensor so I am guessing that the performance was less than optimal. Wiped the worst of the crud off and then a quick blast of WD40 dissolved the rest away. Have only driven about 1 mile since but the car seems quieter under gentle acceleration (after I had an EGR valve replaced in January the car seemed to make more noise- possibly the MAP sensor is getting a more accurate reading and keeping the valves closed?), will see if there are any further improvements to note in the coming days. |
Don't know yet, after i cleaned it i put it straight into my garage, i will let you know tomorrow, i'm not sure i will notice any difference because ive just had it remapped and boy what a difference that has made to the power ![]() ![]() |
Been kind of watching the remap debate here, seems much more common D3side than here. For me it's a case of which remap, whether to remap or not doesn't even come into it. Had 2 cars remapped & never had any issues related to that. Also never had any problems with warranty work with dealers, never had to remove it. Most stealers sell remaps anyway at inflated prices. Getting my remap put back on Thursday, lost when new turbo fitted.
kieltdv8 Member Since: 22 Dec 2010 Location: perth Posts: 119 ![]() ![]() ![]() |
Hi
Don't know for sure, I'm not techie, but can't see why not. If it's easily accessible deffo worth a try, though I've no idea where it is as LR couldn't be bothered putting the TDV8 in D3s. |
[quote=
