![]() | Home > Maintenance & Modifications > Cracked Windscreen |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
OK, Once again thanks to you all for the advice |
![]() ![]() ![]() ![]() 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
My car is going to the dealer next Tuesday for Windscreen replacement
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 ![]() ![]() ![]() |
Yes probably a little too harsh.
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
Whats the betting they just subby it back out to Autoglass |
They probably will. My Windscreen was fitted in the workshop but by Autoglass as its not something the service shop do at LR. |
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 ![]() ![]() ![]() |
as land rover insurance paid for it...ask them to write to you to confirm that the windscreen fitted was a genuine land rover part or fully met the original land rover specification for the windscreen. Remind them its a structural item and that should an accident occur you want them to accept liability should in any subsequent investigation the window is found to be at fault. |
Would I need to do this as on my autoglass job sheet it states that a land rover OE screen has been fitted ? Sorry if question is a little niave as I never had a new screen before |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
autoglass supply their own screens i insisted i wanted a LR part fitted which took an extra week or so to procure.
The land rover oem screen has a little land rover badge in the bottom n/s corner |
Foxy - You raise an interesting point and its all about how you personally view the risk.
Just checked and my screen is definitley an OE Screen and is displaying the LR Logo. However, I will put on file the paperwork that autoglass left me....just in case I need to use it a later date.
KiwiRRS Member Since: 22 Aug 2007 Location: Wellington Posts: 92 ![]() ![]() |
I had the same issue when replacing a screen. The insurer want to fit non OEM. I insisted that they fit OEM( in this case a merc screen) . I used the simple logic that if they were prepared to take my large premium for this value car and were prepared to insure the car knowing what likely costs may be. Therefore when an event happened, all I wanted was like for like not an inferior product, nor betterment - they fitted an OEM. |
