Home > General > WHICH TRANSMISSION OIL FOR AUTO GEARBOX? |
marksgd Member Since: 10 Oct 2010 Location: Worcestershire Posts: 68 |
HI Does any one know where is the best place to buy auto gearbox for RRS 06 plate?. Local LandRover dealership wants £24.00 per 1ltr bottle They tell me that it will need 9.5 ltrs £250.00 as near as dam it they also said it has to be the right oil or the gearbox will die.. The reason i want to change it, there is a bit of a shunt from the box when slowing down then putting your foot down on the accelerator. i have read on a thread that changing the oil MAY help to stop it???? |
Fri Mar 18 2011 6:43pm |
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 |
take it to a specialist and get them to change the filter at the same time...should be cheaper and gives you a chance to meet the specialist as well |
Fri Mar 18 2011 6:55pm |
I hear what you are saying ,,, but have you any idea where i can buy the correct oil from. There must be transmission oils that do the same job for a lot less ££ |
Fri Mar 18 2011 7:23pm |
Thanks for that info Ady ill google Millers oils & givem a call |
Sat Mar 19 2011 8:14am |
why dont you get the spec of the oil from the owners manual and search on line...
Sat Mar 19 2011 9:32am |
have done that just.. ive emailed Millers Oils & asked which of there oil meets the requirments of the Shell ATF M1375.4.
Sat Mar 19 2011 11:57am |
Spoke to Millers Oils they gave me a price of £26.00 per 5ltr They assured me it meets the same spec as whats reccomended in the manual. With delivery for 10ltrs £57,00 Inc VAT.. |
Mon Mar 21 2011 7:16pm |
I have been told that there is no filter on this model , the chap says there is a magnetic sump bolt so i aint sure if i need a filter?? |
Mon Mar 21 2011 7:19pm |
Id say get a new sump bolt then, the price of the oil is very reasonable though is it a straight forward job |
Mon Mar 21 2011 9:03pm |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 |
here you go
Mon Mar 21 2011 9:59pm |
Linky please |
Mon Mar 21 2011 10:04pm |
depending on the gearbox the bottom of the gearbox might have to be removed to get to the filter...not quite the same as dealing with the engine oil filter which sits outside the engine sump |
Tue Mar 22 2011 1:35am |
I do hope not. Mind you when you think the job will be a piece of cake it turns out to be a bloody nightmare. Well ill let you know how it goes & the outcome of the shunt when i do the job friday/saturday, |
Tue Mar 22 2011 6:57pm |
ive copied it & paste but nowt comes up ??? |
Tue Mar 22 2011 6:58pm |
