Home > General > WHICH TRANSMISSION OIL FOR AUTO GEARBOX?
marksgd
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
HI Does any one know where is the best place to buy auto gearbox for RRS 06 plate?. Local LandRover dealership wants £24.00 per 1ltr bottle They tell me that it will need 9.5 ltrs £250.00 as near as dam it they also said it has to be the right oil or the gearbox will die.. The reason i want to change it, there is a bit of a shunt from the box when slowing down then putting your foot down on the accelerator. i have read on a thread that changing the oil MAY help to stop it???? Confused
Post #292715 Fri Mar 18 2011 6:43pm
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
take it to a specialist and get them to change the filter at the same time...should be cheaper and gives you a chance to meet the specialist as well
Post #292717 Fri Mar 18 2011 6:55pm
marksgd
I hear what you are saying ,,, but have you any idea where i can buy the correct oil from. There must be transmission oils that do the same job for a lot less ££
Post #292722 Fri Mar 18 2011 7:23pm
I can't believe that changing the gearbox oil isn't in the service schedule, when i asked about it at my dealer yes the price per litre is correct, but he also he told me that you are supposed to change it again shortly after, god knows why i got put off the idea that works out at about £500 + try millers oils website i'm sure they can recommend a replacement oil.
Ady
Post #292754 Fri Mar 18 2011 9:29pm
marksgd
Thanks for that info Ady ill google Millers oils & givem a call Smile
Post #292787 Sat Mar 19 2011 8:14am
ronniet101
why dont you get the spec of the oil from the owners manual and search on line...
think oil gets changed after 10 years.....if you have crap in your box then maybe it needs flushing..so putting some new oil in and then draining sounds right unfortunately..and then a new filter to finish off
Post #292803 Sat Mar 19 2011 9:32am
marksgd
have done that just.. ive emailed Millers Oils & asked which of there oil meets the requirments of the Shell ATF M1375.4.
Hopefully they will get in touch soon , will let you know outcome Smile
Post #292834 Sat Mar 19 2011 11:57am
marksgd
Spoke to Millers Oils they gave me a price of £26.00 per 5ltr They assured me it meets the same spec as whats reccomended in the manual. With delivery for 10ltrs £57,00 Inc VAT.. Very Happy
Post #293207 Mon Mar 21 2011 7:16pm
marksgd
I have been told that there is no filter on this model , the chap says there is a magnetic sump bolt so i aint sure if i need a filter?? Confused
Post #293211 Mon Mar 21 2011 7:19pm
Id say get a new sump bolt then, the price of the oil is very reasonable though Thumbs Up is it a straight forward job
Post #293221 Mon Mar 21 2011 9:03pm
airwolf222helicopters
here you go
[img]http://www.rrsport.co.uk/gallery/albums/userpics/13761/TDV6%20Transmission%20Fluid%20Drain%20and%20Refill.pdf[/img]
Post #293230 Mon Mar 21 2011 9:59pm
airwolf222helicopters wrote:
here you go
Linky please Thumbs Up
Post #293234 Mon Mar 21 2011 10:04pm
ronniet101
depending on the gearbox the bottom of the gearbox might have to be removed to get to the filter...not quite the same as dealing with the engine oil filter which sits outside the engine sump
Post #293246 Tue Mar 22 2011 1:35am
marksgd
I do hope not. Mind you when you think the job will be a piece of cake it turns out to be a bloody nightmare. Well ill let you know how it goes & the outcome of the shunt when i do the job friday/saturday, Very Happy Wink
Post #293307 Tue Mar 22 2011 6:57pm
marksgd
here you go
ive copied it & paste but nowt comes up ???
Post #293308 Tue Mar 22 2011 6:58pm
