Home > General > WHICH TRANSMISSION OIL FOR AUTO GEARBOX?
airwolf222helicopters
hi i have pm martin to find out how
but it is in gallery under 21st of march how it got there i dont know lol
Post #293309 Tue Mar 22 2011 7:08pm
marksgd
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
illhave a look ta
Post #293325 Tue Mar 22 2011 9:21pm
marksgd
Still cant find it Confused
Post #293385 Wed Mar 23 2011 5:58pm
Can someone please explain in laymans terms how to use the search facility properly, everytime i try a search i get everything but what i'm searching for Banging Head
Post #293437 Thu Mar 24 2011 8:36am
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
same here Mad
Post #293505 Thu Mar 24 2011 3:34pm
marksgd
Hi all. Ok just changed the Transmission oil. The Land Rover Dealership told me on the phone that the transmission holds 9.5ltrs . Well i drained the oil out nowhere near 9ltrs came out ..I then refilled the box started the engine & went through the gears 3-4 times. Then drained all the oil back out I then refilled the transmission approx 2 ltrs on the second fill. Drove it home & at the moment no shunts Thumbs Up the wife has drove it to worcester now so i will have a blast around town later to see if it has sorted it. Will let you know the outcome Exclamation The total time from start to finish was 45mins
Post #293760 Sat Mar 26 2011 1:54pm
Which oil did you eventually use?
Post #293764 Sat Mar 26 2011 2:39pm
marksgd
Millermatic ATF DM
Post #293773 Sat Mar 26 2011 5:33pm
hi sorry guys martin hasnt replied back to me regarding how to put up that link i have in a pdf form
if you still want it pm me your email
also i have looked and it says you have to put in 3.5-4 LTRS of new oil so 2 may be not enough
dont want you to end up overheating ur box Thumbs Up
Post #293774 Sat Mar 26 2011 5:42pm
marksgd
Filled it up until the oil came out of the filler so fingers x.. Have just drove it & it still shunts but not as bad. Sad
Post #293775 Sat Mar 26 2011 5:48pm
marksgd
Ill live with it aint gonna bother to flush it again . will have to find out how to do the gearbox update Patch..
Post #293776 Sat Mar 26 2011 5:51pm
marksgd wrote:
Millermatic ATF DM
Cheers Thumbs Up
Post #293813 Sat Mar 26 2011 8:28pm
marksgd
Ok Took the RRs into AllTrack 4x4 the bloke checked i had filled the transmission up properly. It was abit low!! anyway he done the latest transmission updates (Wendsday) Cost me £45.00 & it seems to be all ok Thumbs Up
Post #294669 Fri Apr 01 2011 3:13pm
