Home > Technical > USB Audio Interface |
edvarski Member Since: 08 Feb 2011 Location: Knaresborough Posts: 19 |
Has anyone had any experience getting audio to play from a USB memory stick on an MY10 RRS? I've got an ipod to play fine so the interface is working.
Sat Feb 19 2011 5:22pm |
I've tried it with an 8GB, but I also tried with a 2GB ipod shuffle in disc mode just in case it was a powering issue. Both give the same error.
Sat Feb 19 2011 5:56pm |
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 |
i have used a 4gb in mine, works perfectly, no problems at all.
Sat Feb 19 2011 9:25pm |
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 |
Got a 32GB in mine no issues have also used a 16GB
Sat Feb 19 2011 11:36pm |
stickinthemud Member Since: 03 Dec 2010 Location: Bracknell Posts: 16 |
I'm using a SanDisk 16gb which I formatted in Windows 7 (Computer-G or whatever Drive,)-right click-format-Fat32-Quick format, load music. Plug it in and the RRS system will show all the Music and Artists and give you the choice to play randomly. The same input works on other music players, Archos, Cowan, Sony etc. I've also wired in a little 'Sonichi' DAB player (Halfords) into the Aux socket for permanent Planet Rock the head unit is the size of a packet of 10 fags and is mounted in the top glove box, it works well, much better than my old Pure Highway in my Disco 3. |
Mon Feb 21 2011 2:08pm |
Tail End Charlie Member Since: 10 Aug 2011 Location: Bristol Posts: 14 |
Try checking whether you have any hidden files on the USB....go into Explorer, select tools and then folder options. The tick the box to show all hidden files. Have a look in the directory to see if it shows any rouge files. I have a 16gb Bytestor USB (£10 from Amazon) and it works a treat!! |
Sat Aug 13 2011 3:26pm |
Are you having success with your sony mp3 walkman - mine wont work... I have a 8 or it might be 16gb in there working fine., Mike 2014 Facelift Discovery |
Sat Aug 13 2011 6:19pm |
Worzel Member Since: 27 May 2009 Location: Lancashire Posts: 123 |
Can anyone tell me if this can be retro fitted to a 2007 RRS? |
Mon Sep 05 2011 2:22pm |
