Home > Technical > USB Audio Interface
edvarski
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
USB Audio Interface
Has anyone had any experience getting audio to play from a USB memory stick on an MY10 RRS? I've got an ipod to play fine so the interface is working.
The manual suggests a USB memory stick should work as long as it is FAT or FAT32 formatted, and contains MP3, WMA or AAC files. However, I just get an error message saying 'device error'.
Has anyone got any ideas?
Cheers,
Simon.
Post #289654 Sat Feb 19 2011 5:22pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
What size of USB are you using ?
There has been issues with this documented elsewhere and most recommend using a device smaller than 2GB to start with then inserting the larger device. the smaller the stick the better some larger flash or hard drives may be too power hungry for the port.
Post #289655 Sat Feb 19 2011 5:49pm
edvarski
I've tried it with an 8GB, but I also tried with a 2GB ipod shuffle in disc mode just in case it was a powering issue. Both give the same error.
I'll hunt around and see if I have an old stick around that is below 2Gb and give that a try.
Post #289657 Sat Feb 19 2011 5:56pm
JC1
i have used a 4gb in mine, works perfectly, no problems at all.
Have you tried the USB stick in anything else to check it Question MY10 3.0 HSE Santorini Black, Ivory Premium & extended leather, privacy, paddles, diamond turned alloys, Ipod lead that charges, tasmods, rrsport.co.uk stickers
Jeep 4.0 High Output XJ 94 6" teraflex lift, c/w rear coils, 9500lb winch, 35" TSL super swamper boggers, safari snorkel, custom made bumpers, tom woods custom double cardon driveshaft, twin electric fans. Don't follow it..............you wont make it. The first 4 x 4 by far.
Post #289676 Sat Feb 19 2011 9:25pm
Tboner
Got a 32GB in mine no issues have also used a 16GB
Buy a good quality hi speed pen format it after you get it and remove and name assigned to it from the factory 2014 5.0SC AB
Gone 5.0 SC
Post #289683 Sat Feb 19 2011 11:36pm
stickinthemud
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Fuji White
I'm using a SanDisk 16gb which I formatted in Windows 7 (Computer-G or whatever Drive,)-right click-format-Fat32-Quick format, load music. Plug it in and the RRS system will show all the Music and Artists and give you the choice to play randomly. The same input works on other music players, Archos, Cowan, Sony etc. I've also wired in a little 'Sonichi' DAB player (Halfords) into the Aux socket for permanent Planet Rock the head unit is the size of a packet of 10 fags and is mounted in the top glove box, it works well, much better than my old Pure Highway in my Disco 3.
Post #289769 Mon Feb 21 2011 2:08pm
Tail End Charlie
Try checking whether you have any hidden files on the USB....go into Explorer, select tools and then folder options. The tick the box to show all hidden files. Have a look in the directory to see if it shows any rouge files. I have a 16gb Bytestor USB (£10 from Amazon) and it works a treat!!
Post #309744 Sat Aug 13 2011 3:26pm
mse
Are you having success with your sony mp3 walkman - mine wont work...
I have a 8 or it might be 16gb in there working fine., Mike
2014 Facelift Discovery
Post #309752 Sat Aug 13 2011 6:19pm
Worzel
Can anyone tell me if this can be retro fitted to a 2007 RRS?
Post #312598 Mon Sep 05 2011 2:22pm
