Home > General > What is the optimum cruise control speed for best MPG? |
56mph RRS gone
Fri Jan 28 2011 2:17pm |
kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771 |
I actually tried this out in mine back when i had mine.
Fri Jan 28 2011 3:27pm |
RichardM Member Since: 24 Sep 2009 Location: Herts Posts: 745 |
I found it makes quite a difference sitting behind a lorry, as it creates a slip stream. That's where adaptive cruise is good as it keeps the set distance. I've managed to get higher 30s like that. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Fri Jan 28 2011 3:59pm |
anyone4apint Member Since: 14 Jan 2011 Location: Worcestershire Posts: 31 |
No idea if this is true of the RRS as I have only had mine for 24 hours. However, evey car that I have ever owned has been about 1-2mpg more efficient by turning cruise controll off and doing it the old fasioned way. |
Fri Jan 28 2011 7:00pm |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 |
Isn't it due to the constant braking and accelerating trying to maintain a set speed?
2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
Fri Jan 28 2011 7:13pm |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 |
My indicated mpg over the first 1000 miles all on A, B and single track roads shows 27.7 mpg. Not too bad I thought considering a new tight engine and no long motorway trips. |
Fri Jan 28 2011 8:37pm |
BulletProofBomb Member Since: 12 Jan 2010 Location: Lanarkshire Posts: 164 |
Read a great tip on hear the other day. When on the motorway sitting at 65-70 Manually select 6th then go back to automatic. It may be that you are running in auto in 5th at high revs and the speed is just below where the box would automatically select 6th gear. Selecting 6th yourself then back to auto, the box will stay in 6th gear = lower revs = fuel savings.
Fri Jan 28 2011 11:48pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
55 is ok if using tiptronic mamual selection as you can select 6th gear manually.
Fri Jan 28 2011 11:52pm |
SimonH Member Since: 18 Feb 2009 Location: York, North Yorkshire Posts: 54 |
I find 50 mph is best for mpg but am aware of looking like a road block so tend to settle for 55 mph which appears a bit more acceptable to other road users.... |
Mon Jan 31 2011 1:53pm |
My TDV8 changes into 6th at 50mph without the need to force it with manual selection?
Mon Jan 31 2011 2:21pm |
Boo Member Since: 20 Oct 2010 Location: Hertfordshire Posts: 28 |
Currently my AVG MPG is 17. As you can tell I am unaware of the optimium cruise control speed. 17 ! |
Mon Jan 31 2011 2:50pm |
Mon Jan 31 2011 2:54pm |
Ha!
Mon Jan 31 2011 3:42pm |
terrifying more like
Mon Jan 31 2011 4:06pm |
