Home > General > What is the optimum cruise control speed for best MPG?
L888DER
United Kingdom 2007 Range Rover Sport TDV6 HSE Zambezi Silver
i do a lot of motorway miles and wondered what is the optimum cruise control speed is for the best MPG?
i have TDV6 is that makes a difference.
Thanks You can live in your car but you cant race your house
just put white indicatrs on, have all black badges ready and have quote for rear tints and dvd's
Post #287245 Fri Jan 28 2011 2:04pm
56mph Thumbs Up RRS gone
Post #287248 Fri Jan 28 2011 2:17pm
kam100
I actually tried this out in mine back when i had mine.
I managed to get this, see below, and i was sitting at between 60-70 the whole time.
Was avoiding filling it up obviously! Thumbs Up
Post #287262 Fri Jan 28 2011 3:27pm
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
I found it makes quite a difference sitting behind a lorry, as it creates a slip stream. That's where adaptive cruise is good as it keeps the set distance. I've managed to get higher 30s like that. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #287267 Fri Jan 28 2011 3:59pm
anyone4apint
No idea if this is true of the RRS as I have only had mine for 24 hours. However, evey car that I have ever owned has been about 1-2mpg more efficient by turning cruise controll off and doing it the old fasioned way.
Post #287296 Fri Jan 28 2011 7:00pm
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Isn't it due to the constant braking and accelerating trying to maintain a set speed?
 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #287299 Fri Jan 28 2011 7:13pm
oldcro
Scotland
My indicated mpg over the first 1000 miles all on A, B and single track roads shows 27.7 mpg. Not too bad I thought considering a new tight engine and no long motorway trips.
Post #287305 Fri Jan 28 2011 8:37pm
BulletProofBomb
Read a great tip on hear the other day. When on the motorway sitting at 65-70 Manually select 6th then go back to automatic. It may be that you are running in auto in 5th at high revs and the speed is just below where the box would automatically select 6th gear. Selecting 6th yourself then back to auto, the box will stay in 6th gear = lower revs = fuel savings.
Pretty obvious really, but I never thought of it in the year i've had the RRS. Been trying this for the past couple of days and showing approx 5 MPG better on the display than I normally get. This is with 80 motorway miles a day sitting at around 70 - 80. Very Happy Very Happy Very Happy RRS TDV8 (loving it)
Suzuki Bandit 1200 (For when the suns out)
Nissan 350z GONE
Post #287319 Fri Jan 28 2011 11:48pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
55 is ok if using tiptronic mamual selection as you can select 6th gear manually.
Normally auto box usually does not engage 6th gear until 60 mph so best to be doing just over 60 in normal auto box to get the lower gearing.
Post #287320 Fri Jan 28 2011 11:52pm
SimonH
I find 50 mph is best for mpg but am aware of looking like a road block so tend to settle for 55 mph which appears a bit more acceptable to other road users....
Post #287521 Mon Jan 31 2011 1:53pm
My TDV8 changes into 6th at 50mph without the need to force it with manual selection?
as long as rpm's are over 1,500 it'll change up if light footed RRS gone
Post #287524 Mon Jan 31 2011 2:21pm
Boo
2006 Range Rover Sport Supercharged Bonatti Grey
Re: What is the optimum cruise control speed for best MPG?
Thanks
Currently my AVG MPG is 17.
As you can tell I am unaware of the optimium cruise control speed.
17 !
Post #287529 Mon Jan 31 2011 2:50pm
My TDV8 was on 12 when I picked it up
130 miles later (at errhemm 80 something plus a few Whistle all the way) it was up to 19
So to maintain 17 requires a pretty heavy foot!
Ahhh I seeee supercharged hmmm Thumbs Up RRS gone
Post #287531 Mon Jan 31 2011 2:54pm
Boo
Ha!
12 is impressive.
Post #287534 Mon Jan 31 2011 3:42pm
terrifying more like
I put £60 in it and it went from zero (yes it was truly was empty when I took delivery) to 130 miles of range... almost had a heart attack... Laughing RRS gone
Post #287538 Mon Jan 31 2011 4:06pm
