Home > Technical > Sticking Exhaust gas recirculation valve |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 |
Hi Hulmey
Mon Jan 17 2011 4:54pm |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
Hi, I just had the same problem on my 2007 TDV6, I tried cleaning the valves but it didn't work, the valve is more than likely just sticking and not closing properly. You will need a new valve at some stage I had my local garage do it for the cost of the valve £125.00 and £45.00 labour, they also had a computer to reset the light. You can't blank 2007 onwards euro 4 cars as the sensor on the valve will cause the light to come on. I have a theory that low mileage cars suffer badly because they coke up more quickly. You can use 2 stroke oil afterwards to reduce the soot and coke. |
Mon Jan 17 2011 10:11pm |
AJS Member Since: 25 Mar 2010 Location: OXFORDSHIRE Posts: 9 |
Hi 1JBS, i've got one of the EGR's gone. What is the name of your local garage thats a good price.
Tue Jan 25 2011 9:04pm |
Hi AJS, speak to Sean at S B Engineering
Tue Jan 25 2011 10:19pm |
Thanks JB, Will do. |
Wed Jan 26 2011 7:16pm |
