![]() | Home > Technical > Sticking Exhaust gas recirculation valve |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 ![]() ![]() |
Hi Hulmey
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Hi, I just had the same problem on my 2007 TDV6, I tried cleaning the valves but it didn't work, the valve is more than likely just sticking and not closing properly. You will need a new valve at some stage I had my local garage do it for the cost of the valve £125.00 and £45.00 labour, they also had a computer to reset the light. You can't blank 2007 onwards euro 4 cars as the sensor on the valve will cause the light to come on. I have a theory that low mileage cars suffer badly because they coke up more quickly. You can use 2 stroke oil afterwards to reduce the soot and coke. |
AJS Member Since: 25 Mar 2010 Location: OXFORDSHIRE Posts: 9 ![]() ![]() ![]() |
Hi 1JBS, i've got one of the EGR's gone. What is the name of your local garage thats a good price.
Hi AJS, speak to Sean at S B Engineering
Thanks JB, Will do. |
