![]() | Home > Tips & Tricks > Painting Tailgate Moulding - Help |
I don't think you will get a good finish using spray can's, you need a proper air gun with the right mix right temperature aspecially this time of year, and a good primer, you will need to give it a few coats of primer to build up and get rid of the plastic texture of the trim, spray can's are not the best for spraying paint, they should of stopped at hair laquar's |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 ![]() ![]() ![]() |
Do you think its a waste of money buying paint etc then ? |
I think you will be dissapointed with the results, so yes.
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
you are wasting your time with cans, its only cellulose paint, while the rest of the vehicle is in 2 pack paint,
Thanks guys.
TenBob Member Since: 01 Nov 2010 Location: North Posts: 138 ![]() ![]() ![]() |
Hi, did you get them all painted, and if so, how did they turn out and did you sell them? (interested if not ![]() |
Got 1 left, the other 2 have sold on eBay. I didnt bother getting them painted, i sold my S/C for a 911 C4S |
RRS PIMP Member Since: 05 Nov 2008 Location: London Posts: 110 ![]() ![]() |
You have PM |
felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203 ![]() ![]() ![]() |
Just have a go! What have you got to lose if you have spares. Key the surface prior to spraying use a decent plastic primer, spray the top coat on and leave to dry, make sure you apply the coats carefully, little at a time is always best but get a good few coats on then if it looks a bit orange peely when dry just get some soapy water and some very fine wet and dry ant rub them down, when you rubbed them down polish with rubbing compound then finally with polish. Ive got many good results with spray cans. |
Just a note I resprayed an entire rear of a defender with aresol cans of genuine colour...it can be done and you can get perfect results.
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 ![]() ![]() ![]() |
dont think spray cans have cellulose in them anymore |
