Home > General > Gas Suspension |
marksgd Member Since: 10 Oct 2010 Location: Worcestershire Posts: 68 |
Hi All..Quick question
Fri Jan 14 2011 6:56pm |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 |
Think you'll find it's air - not gas! Cheers Laurence. |
Fri Jan 14 2011 6:59pm |
OK AIR SMART ARSE |
Fri Jan 14 2011 7:05pm |
No need to shout! Cheers Laurence. |
Fri Jan 14 2011 7:13pm |
no need for sarcastic comments.. do u know the answer to my question? |
Fri Jan 14 2011 7:15pm |
Oh dear You did not help me remember , "The question" |
Fri Jan 14 2011 7:45pm |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 |
I don't think it is possible mate. The next best option you have is to programme the key to do this for you through the Land Rover Button. Page 32 of your Owners Manual if you have one. The procedure is as follows: Air Suspension Control Programmed by keeping the Land Rover button pressed and also pressing the suspension control switch. A chime from the instrument panel will confirm successful programming. Programming of this function must be done within 1 minute of switching off the engine. After programming, to change the suspension height via the remote control, remove the starter key, turn on the hazard warning lamps and close all the doors. Remote operation is not possible until this is done. To raise the vehicle press and hold the LR button and Lock Button To lower the vehicle press and hold the LR button and unlock button. Hope this helps you. |
Fri Jan 14 2011 8:03pm |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
nice attitude mate, sure people will be lining up to help you |
Fri Jan 14 2011 8:20pm |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
when the suspension (air) is working correctly it has very little draw on the battery when the car is parked up |
Fri Jan 14 2011 8:58pm |
AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174 |
Air is a gas is it not? |
Sun Jan 16 2011 5:39pm |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 |
Nitrogen (N2): 78.09% Oxygen (O2): 20.95% Argon (Ar): 0.93% Carbon dioxide (CO2): 0.038% Others (less than 0.002% each): Neon (Ne), Helium (He), Krypton (Kr), Hydrogen (H2), Xenon (Xe) ........to be precise. I'm sure Marksgd will be exultant in this factuality L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now! 5 series for the miles RRS S/C factory built HST - Gone 45 others have been and gone! |
Sun Jan 16 2011 6:21pm |
Sun Jan 16 2011 6:28pm |
Yup brilliant |
Sun Jan 16 2011 6:29pm |
