Home > General > Gas Suspension
marksgd
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Gas Suspension
Hi All..Quick question
Can you set the gas suspension to lower automatically when you park up so not to have to flick the switch?? only asking as i had a flat battery & the system was showing faults until it reset itself, & i noticed the gas blow out of the suspension & the vehicle lowered on its own?? Confused Confused
Post #285872 Fri Jan 14 2011 6:56pm
Buster007
Think you'll find it's air - not gas! Cheers Laurence.
Post #285873 Fri Jan 14 2011 6:59pm
marksgd
OK AIR SMART ARSE
Post #285876 Fri Jan 14 2011 7:05pm
Buster007
No need to shout! Cheers Laurence.
Post #285878 Fri Jan 14 2011 7:13pm
marksgd
no need for sarcastic comments.. do u know the answer to my question?
Post #285880 Fri Jan 14 2011 7:15pm
Buster007
I was trying to help you by explaining it is air and not gas!
I thought this was a light hearted, friendly forum didn’t realize people were so up tight?
No mate I’m going to bale out – good luck to the next person that tries to help you if their feeling brave enough! Cheers Laurence.
Post #285884 Fri Jan 14 2011 7:30pm
marksgd
Oh dear Crying or Very sad Rolling with laughter You did not help me remember , "The question" Surprised
Post #285889 Fri Jan 14 2011 7:45pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Re: Gas Suspension
I don't think it is possible mate. The next best option you have is to programme the key to do this for you through the Land Rover Button. Page 32 of your Owners Manual if you have one. The procedure is as follows:
Air Suspension Control
Programmed by keeping the Land Rover button pressed and also pressing the suspension control switch. A chime from the instrument panel will confirm successful programming.
Programming of this function must be done within 1 minute of switching off the engine.
After programming, to change the suspension height via the remote control, remove the starter key, turn on the hazard warning lamps and close all the doors. Remote operation is not possible until this is done.
To raise the vehicle press and hold the LR button and Lock Button
To lower the vehicle press and hold the LR button and unlock button.
Hope this helps you.
Post #285892 Fri Jan 14 2011 8:03pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
marksgd wrote:
OK AIR SMART ARSE
nice attitude mate, sure people will be lining up to help you Thumbs Up
Post #285897 Fri Jan 14 2011 8:20pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
when the suspension (air) is working correctly it has very little draw on the battery when the car is parked up
Post #285901 Fri Jan 14 2011 8:58pm
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Air is a gas is it not? Whistle
Post #286044 Sun Jan 16 2011 5:39pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Nitrogen (N2): 78.09%
Oxygen (O2): 20.95%
Argon (Ar): 0.93%
Carbon dioxide (CO2): 0.038%
Others (less than 0.002% each): Neon (Ne), Helium (He), Krypton (Kr), Hydrogen (H2), Xenon (Xe)
........to be precise. I'm sure Marksgd will be exultant in this factuality Wink L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #286048 Sun Jan 16 2011 6:21pm
marksgd
Re: Gas Suspension
Cheers ill try that Thanks Wink
Post #286050 Sun Jan 16 2011 6:28pm
marksgd
Oxygen (O2): 20.95%
Argon (Ar): 0.93%
Yup brilliant Confused
Post #286051 Sun Jan 16 2011 6:29pm
