![]() | Home > General > Passenger door lock settings |
BulletProofBomb Member Since: 12 Jan 2010 Location: Lanarkshire Posts: 164 ![]() ![]() ![]() |
Just had a similar problem, door wouldnt lock/unlock with the key fob. Turned out to be a faulty door latch. £95 dealer fix which included labour. Check out this thread on the Disco site, seems to be a pretty common fault. http://www.disco3.co.uk/forum/topic19134.html
gordon kerr Member Since: 14 Jan 2010 Location: Bedford Posts: 49 ![]() ![]() ![]() |
Mine is similar in that it does not unlock the passenger doors until I take the keys out of the ignition or press the button - I thouhgt that was how it was meant to work! Maybe that isn't what you are describing though |
alanad Member Since: 01 Dec 2010 Location: Livingston Posts: 133 ![]() ![]() ![]() |
Have you perhaps got single entry configured:
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 ![]() ![]() ![]() |
Gordon - exactly what mine does.
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
Thank you sir, that was getting right on my nerves lol i will be changing mine as soon as i get home. |
Interior release cable? Malaysia Boleh!
I've Looking into this further (from the passengers door prospective).
I assume you're referring to the front passanger door...
Bobby, wowwww.!
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 ![]() ![]() ![]() |
pcregeen Member Since: 06 May 2010 Location: Huddersfield Posts: 100 ![]() |
The RRS is designed as follows. Open car, drive off and doors auto lock. Unless the car is stopped (engine off and keys out) or the dashboard button is pressed, then no passenger door or boot can be opened from the inside or out. This, i understand is to prevent hi jack of the doors even with windows open and to prevent anyone opening doors while height being adjusted on suspension etc (which requires doors to be closed).
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 ![]() ![]() |
I had the same issue with my RRS, dealer informed me that this was an issue with the latch mechanism and that the whole thing would be replaced. Happily this was done under warranty. Works perfectly now |
Where did you get this information? ![]() Does your RRS do that? ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
![]() I've lost count the number of times swmbo tries the door on the 1st unlock... ![]() Problemo solved cheers ![]() Audi SQ5...Gone Audi Q7 S-Line 240 3.0TDI Gone Audi A6 Allroad Sport 270 3.0TDI |
