Home > General > Passenger door lock settings
UK Guy
England 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Annoying problem with passenger door. Here goes -
The passenger cannot open the door unless i press the unlock on the dash.
Does anyone know a solution?
P.S
(car auto locks doors when driven setting is on). RRS HSE with a few extras & a
2013 RRS Autobiography
Post #282780 Sun Dec 12 2010 2:54am
BulletProofBomb
Just had a similar problem, door wouldnt lock/unlock with the key fob. Turned out to be a faulty door latch. £95 dealer fix which included labour. Check out this thread on the Disco site, seems to be a pretty common fault. http://www.disco3.co.uk/forum/topic19134.html
Bullet Thumbs Up
Post #282783 Sun Dec 12 2010 7:36am
gordon kerr
England 2007 Range Rover Sport TDV6 SE Java Black
Mine is similar in that it does not unlock the passenger doors until I take the keys out of the ignition or press the button - I thouhgt that was how it was meant to work! Maybe that isn't what you are describing though Confused Gordon Kerr
Bedford, UK
2007 Java Black RR Sport TDv6
1980 Brooklands Green Triumph TR7
Post #282794 Sun Dec 12 2010 10:48am
alanad
Scotland 2013 Range Rover Sport SDV6 HSE Bonatti Grey
Have you perhaps got single entry configured:
SINGLE/MULTI-POINT ENTRY
When you press the unlock button, your
vehicle will unlock in one of two ways:
1. Single Point Entry: Unlocks the driver's
door and fuel filler flap only. A second
press is required to unlock the remaining
doors and the tailgate.
2. Multi Point Entry: Unlocks all doors, fuel
filler flap and the tailgate on the first press.
Single point entry can be disabled on individual
Smart Keys by unlocking the vehicle then
simultaneously pressing and holding the lock
and unlock buttons for 3 seconds. The vehicle
will lock and then unlock and the hazard
warning lights will flash twice to confirm the
change. You can now unlock all doors with a
single press. Repeating the procedure will
re-enable Single point entry. 3.0 SDV6 HSE Dynamic, Corris Grey with contrast Santorini Black Panoramic Roof, lunar interior, privacy glass, upgraded Meridian system, cooled 18 way front seats, heated steering wheel, adaptive xenons, large screen wash bottle.
Gone: 3.0 TDV6 HSE, Santorini Black, Ivory/Lunar interior, grand black lacquer finish, HK Logic 7.1 Surround, Privacy Glass, Adaptive Xenons, heated steering wheel.
Gone: Jaguar XF Luxury, Pearl Grey, Dove Interior
Post #282800 Sun Dec 12 2010 11:56am
UK Guy
Gordon - exactly what mine does.
Sorry guys I don't think I explained it well.
I press the unlock twice On key - passenger gets in no problem. When I drive off the doors lock automatic - it when the passenger wants to get out I either have to press the unlock button or take keys out of car which unlocks all doors.
I don't think it's a fault with the car as it does open if keys taken out or unlock is pressed - the annoying thing is the passanger pulling the handle and the door is locked and can't be unlocked until key out or open button pressed. The drivers door opens the locked door ok so why should the passenger one not. Which is what I would expect!
It's like a child lock for the front passenger door!
Got to be a setting somewhere Question RRS HSE with a few extras & a
Post #282829 Sun Dec 12 2010 4:58pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Thank you sir, that was getting right on my nerves lol i will be changing mine as soon as i get home.
Post #282832 Sun Dec 12 2010 5:21pm
Bobby
Interior release cable? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #282875 Mon Dec 13 2010 9:22am
UK Guy
I've Looking into this further (from the passengers door prospective).
Can someone try this for me on their rrs.
Get into the passenger side - pull the door closed then press the lock button on the dash.
Then pull the door handle to get out of the car. Will it open ?
Mine won't... I can't even pull the unlock tab (which is below the handle) it still won't unlock. Pressing the unlock button on the dash is the only way.
Alanad... Thanks for the single click entry tip. Works great.
Interior release cable - tell me more please.
(this is starting to sound that there is a fault rather than a setting issue!)
thanks again RRS HSE with a few extras & a
Post #282930 Mon Dec 13 2010 8:00pm
Bobby
I assume you're referring to the front passanger door...
Separate release cables are connected between the door latch and the interior door handle, and between the door latch and the exterior door handle. In the left front door, a third cable is connected between the door latch and the door lock in the exterior door handle.
The lock and superlock motors control the engagement of the latches with the release cables to lock and unlock the vehicle. When the vehicle is locked, the lock motors disengage the latches from the exterior release cables. When the vehicle is superlocked, the superlock motors also disengage the latches from the interior release cables. When the vehicle is unlocked, the CJB (central junction box) reverses the lock and superlock motors, to re-engage the release cables, by changing the polarity of their power and ground connections. To enable the SPE (single point entry) function, the lock motor in the driver door latch is operated by two dedicated connections with the CJB (central junction box) ; the lock motors in the other three doors are all operated by two (other) common connections with the CJB (central junction box) . The superlock motors in all four door latches are all operated by two common connections with the CJB (central junction box) .
All of the interior door handles incorporate a locking button. Pressing the front of the locking button pushes the
interior release cable, which causes the door latch to disengage from the exterior release cable. On the rear doors, the button also disengages the interior handle from the interior release cable.
Pulling the front of the locking button out again re-engages the interior door handle with the interior release cable, and also pulls on the interior release cable. This causes the door latch to re-engage with the exterior release cable.
Cool Malaysia Boleh!
Post #282971 Tue Dec 14 2010 1:51am
UK Guy
Bobby, wowwww.!
Where do you guys get this info from!
I bet it's your bed time Reading!
I'm not sure if I fully understand it, but I'm sure my indi will. I must have one of the cables disconected!! Big Cry
Again thanks for the info. I will get this looked at hopefully Saturday when I'm getting polybushes fitted to the arb's by my indi RRS HSE with a few extras & a
Post #283033 Tue Dec 14 2010 8:29pm
RRS_PAT
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I have a similar sounding issue where my rear passenger door won't unlock from time to time but then will work fine for a few days. It isn't the entry setting as all other doors are open. I can hear the noise of the motor going but the black button on this door does not move. I have had the wood trim off to see that the cable is correctly attached and all seems well.
To me it seems that the latch needs replacing as the motor isn't working properly but I am confused why it works sometimes and not others??
Does anybody have any ideas please??
Thanks in advance. 2011 Autobiography Santorini Black
Post #283788 Wed Dec 22 2010 11:26am
pcregeen
The RRS is designed as follows. Open car, drive off and doors auto lock. Unless the car is stopped (engine off and keys out) or the dashboard button is pressed, then no passenger door or boot can be opened from the inside or out. This, i understand is to prevent hi jack of the doors even with windows open and to prevent anyone opening doors while height being adjusted on suspension etc (which requires doors to be closed).
So to summarise, not a fault. just another design quirk!! Thumbs Up
Pete
Post #283798 Wed Dec 22 2010 3:23pm
simon1233
I had the same issue with my RRS, dealer informed me that this was an issue with the latch mechanism and that the whole thing would be replaced. Happily this was done under warranty. Works perfectly now Smile
Irritatingly I now have an intermittent fault with the rear passenger door not always opening on the first press of the key (I have configured the key to open all doors on the first press). Land Rover have oiled that latch in the hope that this improves the performance as the warranty company won't pay out for a new latch mechanism until a 'permanent solution' is required...
Post #284977 Thu Jan 06 2011 1:41pm
Bobby
pcregeen wrote:
The RRS is designed as follows. Open car, drive off and doors auto lock. Unless the car is stopped (engine off and keys out) or the dashboard button is pressed, then no passenger door or boot can be opened from the inside or out. Pete
Where did you get this information? Surprised
Does your RRS do that? Shocked Malaysia Boleh!
Post #284986 Thu Jan 06 2011 2:05pm
I've lost count the number of times swmbo tries the door on the 1st unlock... Thud
Problemo solved cheers Thumbs Up RRS gone
Post #285030 Thu Jan 06 2011 5:51pm
