Home > Technical > Windscreen washer Motor
marksgd
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Hi Does anyone know where i can find the fuse for the windscreen washer motor? its not under the bonnet as ive looked loads of fuses there , but not for the washer. It was making its noise the other day but now it does not make a sound i know its frozen but the motor should still sound even if no water comes out Right??????
Post #283608 Mon Dec 20 2010 6:36pm
No! Mine have frozen and you can't hear the the motor when trying to engage. Fuse box is behind the lower glove box. RTFM! Wink 2005 Zambezi TDV6 - Gone but not forgotten
Post #283609 Mon Dec 20 2010 6:43pm
marksgd
Cheers for that Very Happy had a look at fuses ...Fuse number F18 5amp had blown popped new one in & bobs ur uncle , motor spins no water though still frozen Wink
Post #283724 Tue Dec 21 2010 6:19pm
pcregeen
Thats two posts with a 5amp fuse. Should be ten minimum and ive upgraded to 15. Still no water but least not blowing fuse
Post #283778 Wed Dec 22 2010 8:13am
smurf
just been sorting my frozen screen wash,got some warm tap water in a squirty bottle and sprayed it onto the jets on the bonnet and headlight jets.then flipped the bonnet and on the bonnet same side as water bottle the hose to the jets is slighly visible,sprayed warm water onto this and now windscreen wash works.simples Very Happy
Post #283802 Wed Dec 22 2010 4:31pm
marksgd
Ill try that tomorrow had a little water skirting today but then stopped Confused
Post #283805 Wed Dec 22 2010 5:48pm
marksgd
Yes i know it was two posts Im sure it said 5amp ill double check that Think you r right Exclamation
Post #283807 Wed Dec 22 2010 5:54pm
marksgd
Hi all well got the water to work on the headlamp washers but nowt on the bonnet windscreen washers there was alittle trickle now nothing nor on the rear prity sure the pipes arnt frozen. Is there a seperate fuse for the windscreen washers ?? also the motor runs when you push the stick. ..My old Ford ranger has got just water in the bottle & they work..
Post #283927 Thu Dec 23 2010 7:20pm
shuzzy
My windscreen washer fuse keeps blowing. It is a 10A fuse which is number 11 if I remembr rightly behind the glovebox. Is a right PITA to change too if you got gorilla hands.
Post #283994 Fri Dec 24 2010 4:19pm
AJS
I have had the same problem, keep blowing the 10 amp fuse for the washer motor. I done some digging and found that LR have issued a Service Bulletin that tells you to uprate the fuse to a 15amp and place a new label on the back of the glove box telling you that fuse F11 is now 15 amp.
Happy New Year guy's.
Post #284491 Sat Jan 01 2011 6:37pm
marksgd
Hi All... Well finallly got to the bottom of why my washer jets would not work.. i must have tried to make them work when there was ice in the motor & it broke all the impeller blades off. Hence no water i took it to the local LR Dealer, their mechanic told me it was abitch of a job "The front wheel had to be removed the mud gaurd had to be totally removed then the motor could be accessed He said it would be a 30-45 min job & cost about £60.00. I bought the new motor of them£17.00.. stuck it on my mates ramp took 4 screws out at the front of the mud gaurd & pulled it back 8 inches left the wheel on ..motor for the windscreen pump was easily accessable changed the motors over, put the 4 screws back in & hey presto it works fine ..Total time to do the job was 12mins.. Ps There are 2 motors for the washers 0ne for the lights & one for the front & rear screen
Happy new year to you all Very Happy Very Happy
Post #284522 Sun Jan 02 2011 12:08pm
Bradders
Nice one. Well done ! Thumbs Up FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #284526 Sun Jan 02 2011 12:50pm
