Home > Technical > How to Reset Service alert.
Page 1 of 3 123>
The procedures described below are relevant to the following European specification models:
Model Chassis Model year
Discovery 3 / LR3 L319 2005 to 2006
Range Rover L322 2002 to 2004
Range Rover Sport (not supercharged) L320 2005 to 2006
1) Procedure to check/reset service status – Distance counter
�� Switch ignition OFF
�� Press and Hold left instrument panel reset button, switch ignition ON to position ‘I’ (accessories)
�� Keep reset button pressed for approximately 5 seconds until the LCD displays ‘RESET SIA’. The
distance to service (e.g. 2150 miles) and the service type (e.g. Inspection/oil service) will be
displayed.
�� Has the ‘Reset Distance’ limit been reached or exceeded?
o NO - Follow instructions in section 2 below
o YES - Follow ‘Reset Distance Counter’ instructions below
Reset Distance counter procedure
�� Press and hold left instrument reset button for 5 seconds. ‘RESET’ will begin to flash on the LCD
display.
�� To reset distance the left hand button should be pressed before the ‘RESET’ message has flashed 5
times
�� The LCD will display ‘END SIA’. Switch ignition off
2) Procedure to check/reset service status – Date counter
�� Press left instrument panel reset button once
�� The LCD will display ‘RESET SIA’ followed by the service due date.
�� Has the ‘Reset Date limit been reached or exceeded?
o NO – Press the left instrument button once. The LCD will display ‘END SIA’ to indicate the
service interval check/reset procedure has been cancelled.
o YES - Follow ‘Reset Date Counter’ instructions below
Reset Date counter procedure
display.
times
�� The LCD will display ‘END SIA’. Switch ignition off 2005 Zambezi TDV6 - Gone but not forgotten
Post #273600 Wed Aug 11 2010 8:56am
domy123
United Kingdom 2007 Range Rover Sport Supercharged HST Java Black
Hi Very Annoyed is there any way of reseting the service indictor on a SC
Post #282418 Wed Dec 08 2010 8:09pm
Adam270
hi i have just triedthe above method but i only have one reset button on the dash and its on the right hand side clock so the above doesnt work is there any other way to reset the service counter all help would be gratefully recieved Very Happy Range Rover Sport 2.7HSE
22" overfich Wheels in Black
s/c Front and side Grills
Rear Screens
HST Rear Spoiler
Quad Exhaust
De Badged Front and Rear
Side Steps
Post #286703 Sun Jan 23 2011 9:39pm
big pimp
Does anyone know how to reset the MY10 service indicator, thanks MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #287720 Wed Feb 02 2011 9:33am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
I believe its a very similar method with the one button on the newer 1st shape RRS...
Post #287746 Wed Feb 02 2011 11:57am
Kidneywiper
The S.I.A. reset procedure detailed here will not work on the sport as this is for 02-05 L322 Rangerover NOT a sport.
Post #288340 Mon Feb 07 2011 8:53pm
2nd Rower
For a MY08 Sport (i.e. One reset button on the instrument panel) it is something like this:
Hold down Reset Button
Turn Key to position 1 (so dashboard lights up)
"Service" will flash 4 times on the milage display
(You can release the button as soon as "Service" appears)
"dist" then appears on the milage display.
(Now this is where my memory is vague)
Depending on the type of service being indicated (distance covered, or elapsed time from last service) you need to either reset the "dist" service or toggle to "date".
To toggle to date, hold down the rest button for a couple of seconds. When "date" is displayed further pressing of the button through the display options confirms resetting of the service indicator
Usual caveats apply that any one following the above comments does so at their entire own risk
Post #288344 Mon Feb 07 2011 9:13pm
m14rsh
England 2005 Range Rover Sport Supercharged Buckingham Blue
So how do I reset the service indicator on my 2006 (55) S/C??? 2005 (55) RRS 4.2 V8 S/C Buckingham Blue
All bulbs changed for LED's
Graphite Powder Coated 20" RRS S/C Alloys
Side Steps
Tints
http://rrsport.co.uk/forum/topic1760-45.html
Post #291744 Wed Mar 09 2011 11:17pm
flight
Just tried it on my 2006 2.7... I have one button on the right and it doesn't seem to work. Anyone know a step by step on one button version?
Post #307087 Sat Jul 23 2011 2:33pm
flight
Anyone??
Post #307182 Sun Jul 24 2011 8:59pm
You can't do it manually, i'm afraid its a trip to the dealers for them to plug it in to their machine, i had the same problem, £50 was the cost Big Cry
Post #307184 Sun Jul 24 2011 9:06pm
flight
Does anyone know an independant dealer in north london that could do the reset?
Post #307191 Sun Jul 24 2011 9:52pm
garrycol
Australia
I have the workshop manual downloaded for my specific VIN - it has a manual process but it does not work (in fact I can not actually follow it) - why put it in if it does not work? typical landrover crap.
Landrover want you to get work done on their cars at their dealerships - might be OK in the UK bur not in Aust wherem dealerships are being wound back and owners might have to drive a 2000km round trip to get their vehicles serviced - then most landrover dealers are not better than the local backyard mechanic but they do have the computer gear - but then the local mechanic tries to actually diagnose issues rather than waiting for a computer which just says - replece diff or replace gearbox.
Landrover have lost the plot - they are now Europe centric and their products are not fit for use (maintenance wise) outside metropolitan areas.
garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #307197 Mon Jul 25 2011 1:18am
AJS7
Gary,
Does your downloaded workshop manual cover the RRS Tdv6 2006 model?
Where did you get this from?
Thanks
Post #360768 Wed Oct 24 2012 6:18pm
garrycol
Australia
I paid for a subscription to Topix and downloaded the required sections from there. You download what is required for your VIN.
http://topix.landrover.jlrext.com/topix/i18n/index#
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #360829 Thu Oct 25 2012 1:19am
Page 1 of 3 123>
