![]() | Home > Maintenance & Modifications > Push Button Start / Stop - Is upgrade possible for pre 2010 |
I think MDP tried it...
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 ![]() ![]() ![]() |
Having it in the ash tray wasn't in my plans but the button itself looks ok, don't think its the same as the 2010 OEM is it though ?. |
The above was actually in response to your first question - that it's possible. |
Ah ok, cheers Bobby. |
markryan15 Member Since: 30 Oct 2015 Location: Virginia, USA Posts: 22 ![]() ![]() ![]() |
Sorry to bump a very old post. But I was wondering if this has been done yet, without the button in the ashtray? I also would like it to be genuine LR, but if not, I'd consider aftermarket kits..
deano_123 Member Since: 13 Aug 2015 Location: Newcastle Posts: 108 ![]() ![]() |
You would still need the use of the key for ignition lock, ignition on etc so a pretty pointless gimmick to me. I had the same in my old DC5 and RS4, you use the key for ignition then a button, completely pointless |
I couldn't just disable the steering lock? |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 ![]() ![]() ![]() |
Exactly, Honda S2000 uses the same trick which is utterly annoying. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
