Home > Technical > Grass, gravel and snow setting |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
Having just done a 40 odd mile trip on the GGS setting my right leg is about to fall off! The RRS behaved impeccably in the snow and slush and ice but I had to give the accelerator a serious push to keep the car moving and to maintain a cruising speed.
Thu Dec 02 2010 11:08am |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
Yep sounds normal, at first it feels like you are driving through treacle
Thu Dec 02 2010 11:18am |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
Yes it is, Ive been driving in GGS mode and like last year Im very impressed with it. |
Thu Dec 02 2010 11:19am |
musher Member Since: 07 Feb 2010 Location: portsmouth Posts: 44 |
are you restricted to any speed in this mode??? |
Thu Dec 02 2010 1:36pm |
no.......well yes, 120mph |
Thu Dec 02 2010 1:46pm |
Not that I have noticed certainly up to 120km/h on the motorway around here, but are you going to be travling that fast in slippy conditions? Sons of dogs come hither and get flesh
Thu Dec 02 2010 1:47pm |
so what does this mode actually allow the car to do and how does it work??? |
Thu Dec 02 2010 2:19pm |
it modifys the throttle response in making you have to press the pedal harder to get a little more speed ie it gives you very little at the start. It also engages the centre diff lock (and rear diff lock if you have it) and makes them more sensitive to wheel slip also brings in the traction control and ABS to modify wheel slip.
Thu Dec 02 2010 2:31pm |
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 |
Alicatt - Love the vid im going to try that MY10 3.0 HSE Santorini Black, Ivory Premium & extended leather, privacy, paddles, diamond turned alloys, Ipod lead that charges, tasmods, rrsport.co.uk stickers Jeep 4.0 High Output XJ 94 6" teraflex lift, c/w rear coils, 9500lb winch, 35" TSL super swamper boggers, safari snorkel, custom made bumpers, tom woods custom double cardon driveshaft, twin electric fans. Don't follow it..............you wont make it. The first 4 x 4 by far. |
Thu Dec 02 2010 4:55pm |
TREV500 Member Since: 21 Jul 2009 Location: Surrey Posts: 58 |
Hi guys loving the snow and the GGS mode, now the reason it feels sluggish to pull away is it's in second gear, you can see this if you select manual mode. Also it won't change past 3rd gear, again if u use manual mode you'll see. It selects 2nd to stop you mashing the throttle and spinning the tyres. You cam overide in manual, also doesn't go past third to stop you going to fast which you wouldn't want to do if conditions are that bad! If you have the 4 x 4 screen on you will notice only transmission and rear axle diffs only lock when needed, again if you mash throttle you only cause the TC to cut in. I find manual mode in GGS the best, as when ur slowing at an icey junction you can select 1st to give extra engine braking.
Thu Dec 02 2010 9:35pm |
NeilR Member Since: 21 Jun 2005 Location: wakefield/West Yorkshire Posts: 246 |
Old stager.
Thu Dec 02 2010 9:38pm |
Cheers for all the replies - good to know mine works ok.
Thu Dec 02 2010 10:21pm |
