Home > Technical > PTI/Bluetooth problems... |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 |
Drivers side rear.
Thu Oct 14 2010 3:08pm |
AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174 |
I've got a spare one!!
Thu Oct 14 2010 6:54pm |
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 |
Carlos, if you can do take some pics of the sequence for removal, sounds simple but pictures are always better!
Fri Oct 15 2010 10:41am |
Hi kismet
Wed Oct 20 2010 12:08pm |
Hi Carlos
Thu Oct 21 2010 3:53pm |
Hi kismet
Thu Oct 21 2010 4:02pm |
Hi
Fri Oct 22 2010 9:07am |
As promised an update on the above; dealership just called to state they tested the PTI module, needs replacing - at a cost of £337
Mon Oct 25 2010 12:05pm |
That's bad news mate. I hope mine isn't the same.
Mon Oct 25 2010 12:12pm |
Mon Oct 25 2010 12:43pm |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Hey Guys just found this link:
Mon Oct 25 2010 3:54pm |
Mon Oct 25 2010 4:11pm |
Kismet, I think they've taken the easy option. The PTI module from their demonstrater will be the newer version of the module and software. They need to check what software is installed on your PTI and demonstrate this to you either on screen or as a print out. If you have the newest software for the old PTI and it's not working then fair enough you need a new module as the cradle works... 2006 RRS S/C CONSTANTLY under modification...
Mon Oct 25 2010 4:23pm |
Tue Oct 26 2010 12:54pm |
