![]() | Home > Technical > PTI/Bluetooth problems... |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 ![]() ![]() ![]() |
Drivers side rear.
AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174 ![]() ![]() ![]() |
I've got a spare one!! |
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 ![]() ![]() ![]() |
Carlos, if you can do take some pics of the sequence for removal, sounds simple but pictures are always better!
Hi kismet
Hi Carlos
Hi kismet
Hi
As promised an update on the above; dealership just called to state they tested the PTI module, needs replacing - at a cost of £337 |
That's bad news mate. I hope mine isn't the same.
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Hey Guys just found this link:
Kismet, I think they've taken the easy option. The PTI module from their demonstrater will be the newer version of the module and software. They need to check what software is installed on your PTI and demonstrate this to you either on screen or as a print out. If you have the newest software for the old PTI and it's not working then fair enough you need a new module as the cradle works... 2006 RRS S/C CONSTANTLY under modification...
