Home > Technical > Garage Door Openers
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
MDP wrote:
Here is a pic of my Horman micro remote control opener.
It is this small ! So no need for homelink
That looks like the perfect size (for me to lose...)
Post #96839 Fri Mar 23 2007 5:17pm
The Homelink UK site says that lots of car mfrs install it in their cars.... I'm assuming that the list isn't simply copied from the US site in that respect - but the usual suspects: Audi, BMW, Porsche, VW, Alfa, Lexus and a few more... I must admit I've never seen a car in the UK with built-in homelink controls. I'm sure the only electric gates I've ever passed through have been with a little keyfob as above...
Maybe this is worth running past LR CS?
Post #96841 Fri Mar 23 2007 5:29pm
We have it on the SL never got it to work though Big Cry Big Cry RRS TDV6 Gone but still around
Post #96868 Fri Mar 23 2007 8:01pm
I've connected a few 'homelink' systems up to our control systems - just a matter of synchronising them, however it is a pain in the a**e - it can take a while for it to get working - once connected, I believe its fine - never had the customers come back to us yet Confused
Post #96869 Fri Mar 23 2007 8:07pm
RAD
Scotland 2009 Range Rover Sport TDV8 HSE Stornoway Grey
The Homelink frequency is different to UK authorised ones, although I know a few people that bought receivers in Sears whilst visiting the US.......in which case it will work. Hormann is pretty much the standard over here and they do 3 different sized remotes including one that has four programmable buttons.
Last car, I bought the US remote package and changed the bits with UK ones, it worked – but really did take some time and I certainly won’t be doing it again. A bit of double sided tape just to the right of monitor and it works just fine.
Good luck! 'Razz' .
There is absolutely no substitute for a genuine lack of preparation.
TDV8 HSE MY10 with pretty much everything including a vase of daffs on the back shelf, tropical fish collection in the centre console, hamsters in the spare tyre and finally sheep on the passenger seats.....for weight distribution, what else??
Post #96870 Fri Mar 23 2007 8:15pm
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
So when i get my gates and garage doors sorted you are the man to get it all working then Thumbs Up some of my Previous cars
P38 Range Rover Autobiography
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
RRS 3.0 HSE BALTI BLUE
current vehicles
RRS 3.0 L494 Autobiography
Audi R8 V10 Spyder
AC Cobra
Landrover Defender 90
Landrover Defender 110
Suzuki Jimney
Post #96887 Fri Mar 23 2007 11:45pm
oldcro
Scotland
I have the Homelink option in my RRS and also a Hormann garage door. The problem is I cannot get the one to speak to the other, programming the Homelink transmitter is a real pain and any advice would be much appreciated.
After many attempts following the RRS manual instructions nothing happens, so tried resetting the Homelink to try again.
Press the two outer buttons until the light flashes it says, pressed until my arms were falling off and still no flashing light.
Has anyone ever managed to get Homelink to actually control a Hormann garage door opener, if so please explain what you had to do to achieve this? Big Cry
Post #278117 Sun Oct 17 2010 8:19pm
Stephen.Gazard
Personally I don't keep my remote in the car .... have seen too many cars stolen that potentially wouldn't have been if the thieves hadn't been able to open the garage and gates and simply drive out !
Post #278137 Mon Oct 18 2010 8:04am
Tim in Scotland
Stephen that is not a problem in Shetland............................. getting cars off the islands without anybody noticing is the problem there Whistle 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #278139 Mon Oct 18 2010 9:01am
oldcro
Scotland
Stephen, I am referring to the Homelink remote which is built into the rear view mirror, it is an option on the 2011 RRS. As Tim says I'm not concerned about theft in this case, I just want to be able to use the built-in remote for my own convenience as opposed to carrying the Hormann remote.
Post #278148 Mon Oct 18 2010 11:01am
oldcro
Scotland
Success! After much fiddling I have managed to get the Homelink in the RRS to control the garage door and outside lights.
This works with the grey remote with blue buttons, 868MHz type.
1. Ignore the instructions in the drivers manual.
2. Reset the Homelink by holding both outside buttons as per instructions (they got that bit right).
3. Hold the remote so the long edge near to the remotes button area is touching the Homelink just behind the three buttons (it will be nearly horizontal) then press the open/close button and the chosen Homelink button until the red light flashes faster or your arm aches. Try moving the remote around the area if no luck. If this fails try using the opposite long edge of the remote.
4. If your opener requires a rolling code you will need to press the red button attached to the opener on the receiver. Mine had a cable about 500mm long with a black box at the end. The black box has a short thin wire aerial at one end and near that is the red button.
5. Press the red button and within 10 seconds (some assistance helps here) press the chosen button on the Homelink for three seconds, release and do the same thing again.
6. If you're as lucky as me that should be it, you do need to press the button for three or more seconds to get the door to move by the way. Mr. Green
Hope this helps.
Post #278163 Mon Oct 18 2010 1:20pm
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
I'm having trouble as well with the wife's one.... Laughing
Post #278166 Mon Oct 18 2010 2:43pm
Rislar
^^^ Shocked Rolling with laughter ^^ If it aint broke leave it!
MY 18, Autobiography
MY 05, 07, 10,
Post #278170 Mon Oct 18 2010 5:53pm
