Home > Technical > Upper tailgate release
Page 3 of 4 <1234>
Another Global Warmer
Any tips or do/donts for the removel of the switch........ Only had my RRS for 10 days and realised I have this problem Crying or Very sad
Thanks
Post #277716 Mon Oct 11 2010 5:10pm
What no tips etc Big Cry
Well for anyone with the same problem its good news...... an easy fix!
Took the switch out and apart and it looked just as the previous photos.
One thing I would add is that its the switch unit that has the fault not the actual microswitch!
If you want a quick temp fix take the switch unit apart, removing the spring and switch flap/paddle (easy to see in the photos) sandpaper the living daylights out of the hinge pin area of the flap/paddle and put it back together (the issue is that the hinge pin area becomes so corroded that it becomes stiff, add this to a very weak spring and the problem is that the flap/paddle is not pushed away from the micro switch allowing it to switch on or off and doesnt release the power feed and can cause a flat battery)...... problem solved for now........ then order a new unit to replace as it will happen again!
Post #277775 Tue Oct 12 2010 4:22pm
m14rsh
Sorry for delay in responding.
As i see you have already completed it.
it is easy, the only thing i now notice is that the switch hasn't and won't fully clip into place and has been slightly out of the socket when i have popped the lid (after driving) and when i close it.
I think i may put something simple like blue tack or a small spot of super glue onto the plastic catch to hold it in fully.
i shall still try and put the video on here. 2014 RRS
Post #277779 Tue Oct 12 2010 4:51pm
It appears the previous owner had the same issue with one of the lights to the side of the switch as it was taped into place as he had snapped one of the clips/pegs, with the external decorative panel removed (see the photos on my other post) you can get easy access to the back of the switch and lights and can just pin/screw into place.
Post #277780 Tue Oct 12 2010 4:58pm
Well here we go again.........
Ive had a flat battery twice now but had assumed it was connected to the corroded switch issue as in another thread
http://www.rrsport.co.uk/forum/topic18772.html
But...... Went out to the bl%*dy thing this afternoon and yes youve guessed right a flat battery awaited me! Grrrr!
I can hear the switch clicking when I touch it so I know its not that stuck in any position causing a live drain.
Any suggestions anyone?
Tried putting a meter on it to test for a drain but its only occasional so catching it is like winning the lotto.
( Reminds me of a Mark 4 escort convertible I had with the same problem, it took weeks of thinking outside the box until we discovered it was a relay that water had got into, rusted away the little spring to diconnect the live feed resulting in the connection just flapping around. 'Heads or Tails' situation, when driving it would bounce/flap around and when you stopped it landed either 'off' or 'on/live'............ heads = battery good next time, tails = battery dead as a dodo)
Post #277844 Wed Oct 13 2010 5:14pm
Rislar
I've just replaced mine after reading this! Mine was shot but no water in it just a perished switch!! Thanks chaps another job sorted! PS I changed the battery also as it was well shot after the power drain!! If it aint broke leave it!
MY 18, Autobiography
MY 05, 07, 10,
Post #278036 Sat Oct 16 2010 2:32pm
baxc
hi it will be your micro switch thats causing the flat battery as the corrosion will have got into the switch itself for the sake of �30 its better to buy a new one than clean the original one up Thumbs Up
Post #278061 Sat Oct 16 2010 7:41pm
rrsjo
Probably due to a faulty battery - a cell intermittently shorting out. I've just had the same problem. OK one minute, flat battery the next. When I put a charger on mine it came back up from 10 volts to 14.4 volts in 5 minutes and was perfectly OK again - until next time. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #278103 Sun Oct 17 2010 12:45pm
Well the new switch bought from fleabay arrived this morning and as M14rsh has already said it has a sticky substance bedding the rubber to the switch housing to prevent water from getting in.
Time to go and fit it I guess, fingers crossed!
Just as an add on..... after cleaning and refitting the original switch last week the tailgate was working perfectly however I still had the battery problem which now had some interesting readouts on the dash which werent there before.......
1st one - 'tailgate open', checked and it wasnt so opened and closed a few times
message went to be replaced by.....
2nd one - 'HDC fault, system not available' , lasted for approx 5 seconds
3rd one - 'DSC off' , pressed the DSC switch and it came back on
After 20 mins of driving switched ignition off and back on again with no messages present so guessing the 2nd and 3rd were due to low battery power.
Will update later Thumbs Up
Post #278142 Mon Oct 18 2010 9:26am
quantz
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Interesting. So far I have not this problem, but I'll have it in mind. 2010 TDV6 3.0 HSE Santorini Black Tan Full Leather
Post #292078 Sat Mar 12 2011 7:04pm
hario69
Any advice how to remove the switch?
Thank u
Post #297237 Mon Apr 25 2011 2:18pm
V8KIP
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Following this thread I have just resolved my battery drain problem.
Thank u
I removed mine (with the tailgate shut as I couldn't open it), by pulling the rubber surround off completely then gently pushing a thin screwdriver head into the left hand side which pushed in the tab (similar to the side repeater tabs) whilst pushing the switch out to the left. Once out the connector may be tight to get at especially if you have large fingers, but if you gently pull you should be able to get at it enough to squeeze the tab in.
The guys at Guy Salmon parts said i'd have to remove the whole plastic trim but this certainly wasn't the case!
Post #297506 Wed Apr 27 2011 7:20pm
baxc
glad you solved your battery drain took me weeks of testing to get to this problem Thumbs Up
Post #297512 Wed Apr 27 2011 8:06pm
tomdigym
Scotland 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Changed mines aswell after reading this thread upper tailgate now works perfect.
By the way the dealer was �3 cheaper than ebay
Cheers Tommy
Post #297515 Wed Apr 27 2011 8:24pm
Baron
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Top thread.
Having the same problem.
Thanks Baxc  SDV8 vogue SE.
Corris grey and ivory leather + most of the toys.
Limited edition RRS model number 0001 Smile
Gone TDV8 RR Sport. Never to be forgotten.
Wife has an i8 BMW
Post #306028 Tue Jul 12 2011 9:16pm
Page 3 of 4 <1234>
